HMS Euryalus 1803 - Scale 1:48 [COMPLETED BUILD]
Lucius, awesome build as usual, did you ever consider using the gantry system that is in the Niaid build books ? The framing jig is definitely turning out some great results! Very beautiful!
Wonderfull work Reudiger.
Didn t knew proxxon had this fine saw blade, will order it direct, great tip thx.
Hola, muy buen trabajo, y por lo que se ve bastante complejo, por cierto le has hecho alguna modificación a tu regruesadora proxxon para aspirar el serrín????? Nos podrías enseñar alguna foto de la regruesadora,?????
Hello, very good job, and from what it looks quite complex, by the way have you made any modifications to your proxxon thicknesser to vacuum the sawdust ????? Could you show us a photo of the thicknesser, ?????
Hello Everyone,
attached some photos of my converted thicknesser.
Connect a vacuum cleaner (preferably one without a bag) and let's go. I built and connected a Zyclon vacuum cleaner myself. The conversion is definitely worth it. There are now hardly any chips to be found.
I hope I could help you a little with that.
Greetings
Ruediger (Lucius)
Hello Everyone,
Greetings
Ruediger (Lucius)
Hallo Rüdiger,
you solved one of the biggest problems with the Proxxon thicknesser
even my very small turkish thicknesser from Netmak has a direct vacuum connection, but the much more expensive Proxxon not
Many Thanks for showing us your solution - I will check, if I can adjust mine also in a similar way......
Muchas gracias, muy agradecido por tus fotos, buen invento se lo aplicaré a la mia
Thank you very much, very grateful for your photos, good invention I will apply it to mine
Hola, trabajas muy bien la madera, el peral es de tu país?????? Es muy bonito este peral
Hello, you work very well with wood, the pear tree is from your country ?????? This pear tree is very beautiful
L a construcción que estas haciendo es muy complicada, sobre todo con las cuadernas reviradas, es
Admirable el trabajo que haces,
ENGLISH
The construction you are doing is very complicated, especially with the twisty frames, it is The work you do is admirable,
Muchas gracias Lucius, mi nombre es Miguel, creo que ya se de donde es la pera un saludo
Thank you very much Lucius, my name is Miguel, I think I already know where the pear is from.
