Looking great Peter! Systematically moving your way across the ship! Soon you will be at the main cabin or captains quarters with stairs.
Yes, Dean. Already thinking of what kind of furniture I will place there. Still a few meters/feet of FishHold to go. But I also enjoy building that. A challenge to make all lines run smoothly in height / width / length.Looking great Peter! Systematically moving your way across the ship! Soon you will be at the main cabin or captains quarters with stairs.![]()
I do the same, always thinking ahead and planning the logical order to complete things, and how.Yes, Dean. Already thinking of what kind of furniture I will place there. Still a few meters/feet of FishHold to go. But I also enjoy building that. A challenge to make all lines run smoothly in height / width / length.
Thanxs Jan, AL-FI is working overtimeAs usual your AL-FI building looks terrific. I look forward to your next “modification”.
Jan
Dank Stephan, a comment doesn't have to be long to be appreciated.
Yes Heinrich, I am still building with a smile and looking forwards for Angus's cabin. Dean mentioned it also.Prachtige werk Peter! You can be very pleased with your progress. If the non-decorative items like fish-holds look like this, I can just imagine what you will conjure up in Angus's cabin.
Thanxs Johan. If you enjoy the build and take the time, the items will (almost) come naturally. And a lot of looking at others .....This is what I would like to define as "customization as a form of art"...
That's exactly what I am currently doing; looking at (and of course learning from) others.And a lot of looking at others .....![]()
First made the beam frame around the main mast:
Thanxs Henk.The cutouts are round
How and with what do you make the connections square?
Nice progress made, and nice to see the progress
Great job Peter!After the necessary fitting, measuring, adjusting etc .... placed the 6th wall in front of the 3rd FishHold. As mentioned before, I had to take into account the bilge pumps and the thickness of the mast:
Now you can walk around the mast and the bilge pumps will soon be inside the shelves of the 4th FishHold.
With the new deck beams on the bearing beams:
And everything can still slide in and out.
Also installed the 2nd new bottom beam so that there are now 2 double beams where the decking ends in between:
Just fit in the 'Exploded View' with the hanging mast ends:
Where I again looked at the 2 holes where the masts should be:
They are only filled when both parts are on top of each other, but then you have almost no view of it. There must be another way..... said ALFI .....
If you have already sawed through a hull and a bilge pump, you might as well saw through the masts. First a test of what I had in mind:
Because the half-walls have nibble walls and a partially visible beam in a technical drawing also has a zig-zag conditional end.
In order to fix the mast properly when I install the rigging, I drilled a 2mm hole with the lathe in the underside of the masts:
A Beech 2mm pen will be in it soon.
After the necessary hours of sawing, filing, fitting, filing etc ....
And when I take the masts apart, the holes are now filled:
For the time being, they are dry-fit in place, because I don't know what I'm going to treat the masts with yet.
Anyway, I'm happy with this solution.
Then I can also put this wall and shelves in the linseed oil again.
This is what I called - Master Craftsman!
Thanxs Jim and Johan. I try to be creative and build “out of the box” with the YQ-kit.Of course you know that increasing your interfaces, the difficulty in maintaining those increases exponentially...
It's becoming quite repetitive, but as usual: awesome!![]()
Thanxs for your concern and thinking with me, Dean. Post 1000 in this build-log is to attention to you!Great job Peter!
As you know, with the addition of the cut in the mast, your upper mast orientation with regard to the trestle trees, etc. will be crucial, because your angular orientation is now locked to fit the lower half. However I am sure you have considered this and will clock, or angularly orient, everything accordingly!![]()
