THX Uwe. This show exactly what I meant with the way the anchor buoy was used for an easy location tracker for the position of the anchor.
Thx to Uwe I made the anchor ring thicker than in the AotS drawings.
I ruined my anchor and partly cut of an anchor hand.
The supplied white cotton anchor cable I drenched in a mixture of bitumen and turpentine.
Before fitting it to the anchor ring.
The anchor is now finished for submersion into the sea.
For a sea we need a sea bed, in this case some fine sand.
The sand I mix with resin, in this case a weight ratio mixed clear resin for pours up to 3 cm.
The ship will be in dock first, here it is made of an oak base with plywood walls.
After mixing I pour some 5mm thick layer of a resin sand mixture into my dock. After settling the sand goes to the bottom creating a nice sandy sea bottom. The polution of the sand with some fine wood particles etc I left in as we also see this at the sea bottom.
After settling you burn of the air bubbles with a torch and you get a nice sandy sea bottom.
This looks like a perfect anchoring ground.
Anchor away.
Anchor away.
So good to see all the steps you take.
Great idea and a very good start for this diorama presentation.
You are not using the typical anchor hitch knot, but a different and simlier one...... any reason for this?
because the anchor was lighter for the Alert?
Hi Uwe,
I used the knot as in the AotS book. Normally there are two loops around the main cable, here only one. Maybe it has to do with the weight of the anchor but I am not sure.
Today it is just booring pouring. :-).
To seal the ship against the mould I use tapestry tape. I tape the mould as well as the keel of the ship.
And taped the ship in place.
Now with a quick curing epoxy I seal the joints to avoid leakage.
I set the mould level.
Fit the anchor cable and buoy in their correct spot.
In this case I use deep pour epoxy for an 8 cm pouring. 5 ltr in one pour. I colour it with 1 drop of cyan alcohol ink.
Leave ot now for 7 days to fully harden before I can release it from the mould. Hopefully it will not start to leak, this epoxy is a thin as water so ne leakage at all is nearly impossible. Time will tell. Most probably I will get some airbubles around the cotton rope as it releases air when the epoxy heats up during its reaction.
Today it is just booring pouring. :).
Slowly I am coming to the realization that there must be an awful lot of professional builders on this website. What I'm observing here with numerous builds is just flabbergasting. Superb!
Great work. Love it
About the anchor rope. You used the inside clinch. (Rope ends on the inside of the eye) David Steel mentioned it. This clinch is stronger than the outside clinch. The inside clinch is also used for buntlines on the foot of the sail. A very common way to knot the anchor.
Great work. Love it
Thx Stephan for clearing this issue. Already was afraid I poured in the wrong knot :-) :-)
Unreal.:eek::eek::eek: I just marvel at the level of confidence that Maarten must have. Here you build an exquisite model, cut it, and then mold the whole construction with all its inherent pitfalls. @RDN1965 Johan mentioned "professional". I am sure that professional builders can learn a lot here.
That is really 'out of the box' with that epoxy in the box.
Regards. Peter
Hi Maarten!
Has the casting resin become very warm? Years ago, I melted through a 2 mm thick ABS plastic hull with it when I poured 1/2 liter of casting resin as ballast and for niveling.
Do you have a release agent on the ship or basin to get a smooth surface? I think I see "Tesapack brown" (a packaging tape, very smooth)?
Best regards
Thomas
