I am using the same method as Bluebeard, sanding the bevel prior to installing the plank.Good Morning Glenn. Awesome job, tapering, beveling and twisting thus far. I personally would go Bluebeards method, takes the risk out of those blade slips...I made those on way simpler tasks. Which ever way you are going you are achieving an awesome result. Cheers.
My problem with the blade method is that I often fail to read the grain properly and the cut will follow the grain rather than where I need it to go.
Thank you for the kind words Grant!
