I am not sure, if you prepare / install the template for the ratlines in the correct alignment.Fore mast crowsfeet completed. Now prepping for the ratlines.View attachment 274407View attachment 274408View attachment 274409View attachment 274410
Good point.... They are parallel to the channel which is parallel to the waterline... I think, now I'm questioning myself.... The second picture is what I used to practice making the knots, it doesn't go on the ship. I used extra shroud lines and then tried various threads to figure out what I would use on the ship. They look like they are parallel to the deck...I am not sure, if you prepare / install the template for the ratlines in the correct alignment.
The rat lines should be parallel to the waterline - from the perspective of the photo it is not visible, so therefore ignore my comment if it is like this
STEADY AS SHE GOES. Hold your course, mate. Your model will reward you. (and us too)The rarlines are taking up a lot of time. View attachment 276536View attachment 276537View attachment 276538
Kurt, you are too kind. I will say this model is coming along better than the last one I built in 2000. A lot is being learned, I'm looking forward to my next model.Your USS Rattlesnake is coming along well. I'm going to use your build log as a research source and guide when I build mine. Thanks PGN!
As are we all, buddy!Kurt, you are too kind. I will say this model is coming along better than the last one I built in 2000. A lot is being learned, I'm looking forward to my next model.
Looking very good.Rattlesnake is getting there started last June you have helped greatly both on the building and mental attitude thanks again
