Thank you all for your constructive helpful suggestions. I do have a saw that fits the dremel and will proceed with caution.
Back soon.
Best wishes to all. Phil
Back soon.
There are various ways leading to Rome.The hull sanded and filled. More sanding to do before painting. For painting, does anyone have any tips for painting the thin white border along the water line? I'm thinking I don't have quite the talent for that.
I actually used graphic tape, it is thinner and lays down better IMO.The pinstripe looks like the best plan. They are readily available. Many thanks to all of you for your attention and encouragement.
I will be back. Best regards to all.
You are welcome, glad I can help.Hi Dean,
Thank you for the response. I found it is available in 1/32 inch which seems about right (a little less than one mm). It is available in white.
It is readily available on Amazon, which is quite easy.
https://www.amazon.com/Chartpak-Graphic-Inches-Black-BG3101M/dp/B01LZH5O9W?th=1
Just want to take the opportunity to say how much I admire your work and have been following your build log for every step.
So thank you, it has been very helpful. I am enjoying this build, and hoping to be my best modeling self, but have no aspirations or ability to achieve anything near your level. Most important I am learning many new things.
Best,
Phil
