because I did not install them until now !Good morning, sorry, I don't see the water channel covers under the keel. Why?
Thank youperché non li ho installati fino ad ora!![]()
Due to the fact, that I am in contact with Tom from CAF, I can make here in our forum an anouncement, when I get the info of a re-editionI'm catching up with this, too.
This wood looks gorgeous and of course Your buildings skills are just adding to the beauty of the wood.
This is a very interesting model, i may keep an eye out for when it's available again.
Hallo,Gosch! That looks really good, metal has been blackened so nicely. What did you use for blackening?
The european boxwood is much better for carving, than this one. The density of european is higher.Hi Uwe,
That construction looks ridged enough to really fire that mortar. I see some pyro experimenting on the horizon.
Ps it seems the chinese boxwood is a different one then the european. In China they mainly have buxus microphylla where the european boxwood is buxus sempervirens. Do you notice differences in the wood or is the wood equal?
In the pictures it really looks sublime, but this is ofcourse also due too your work![]()
The Chinese boxwood is off course much more expensive by the raw material in comparison with Cherry, and I guess also the cnc milling will take more time, because it is much harder.The Chinese boxwood looks great, and I prefer it to Cherry wood which is supplied in the full hull Granado.
Hallo Radek,Hi Uwe!
Will you leave the mortar so shiny or do you dim it?
Radek
Hello Uwek, is this the offending area? Thank youworking further on the mortar pit .....
inside of the pit bulkhead octagon several removable boards have to be installed, which will be later on the base for the removable roofs. These are on the long side the 2 times part "4", 2 time "5" and at the short side on exach side the "6". The two roofs will lay on the top of parts 5 and 6 - and you can see, that there is a small step, that the top is not at the same level. This is caused by a small mistake in the kit, the parts "4" are 2mm too high. Tom from Caf was already informed by myself, so he will adjust this in the next batch of kits
Here you can see the mortar sitting inside the pit "non active" -> for "ready for action" the elements inside the pit have to be removed, so that the mortar can rotate
In the following you can see, that the elements "4" are already shortened by the 2mm, also the side covers on one side are prepared
the side covers received the eyelets for lifting
Many Thanks for your interest ---- to be continued .....
Yes - the red marked difference of 2mmHello Uwek, is this the offending area? Thank you
Thanks for your answerYes - the red marked difference of 2mm
these 2mm (red marks) have to be removed from the part 4 (and not 5) along the length - from the bottom
once more here in green the area which have to be removed - here it will be also clear why at part 4 and not 5, the notch for the small carling for the covers have to move down, so, that they are on the same level (blue marks)
as mentioned already, easy to correct, it is only necessary to know and understand - the new kits will be already corrected
