- Dec 11, 2021
Excellent work and great progress Piero!
Beautiful work Piero!
From what I've seen so far, I have no doubts about the quality of those decks by the end of tomorrow...Hoping to finish this "Swiss period" making a good job around deck.
Hi Piero.
You have made some big stept. What a progress!.
But .......... I hope you don't blame me .......... some overview pictures worried me a bit. Because on some shots I saw a bit of twisting in the deck beams.
I'm hoping it's a camera bias with a wide-angle shift? And I worried for nothing.
I mean this photo in particular. I turned your picture a little bit to set your middle rope vertical in the picture and draw some lines even with some deck beams:
But I also noticed it in 2 other pictures.
Do you mean your or my rotation of the photo? Because I turned the photo as a whole in Photoshop and no distortion occurred.If you edit a digital photo (made up of thousands of pixels) by rotating it specifically, the trim is also changed.
As you quoted, now for your theory: ... in the theoretical line! I have not yet seen that with similar photos in the BN Group Build.If you edit a digital photo (made up of thousands of pixels) by rotating it specifically, the trim is also changed. And what you will see is a distortion in the farthest part of the focal plane. And this is because the edited photo is in two dimensions, it lacks depth, which to be recovered digitally, causes a distortion of the pixels on the theoretical Z axis.
Optical, in case of the lens. The end of the table has the same turn clock-wise. But since the tensioned wire is straight, the question occurred to me.Could be and optical distorsione ...
I'm thinking of lens distortion i.c.w. a (light) camera angle. See this: -> Lens Distortion <-
We'll just leave it her at this. Perhaps in the Photographing Thread. This is a build-log!
I am happy that everything is still correct when measured. After this side step, please continue building. Because your 'jigless' build remains interesting to follow.
Hello Piero,
What a very interesting conversation between you and Peter!
I noticed the deviation mentioned by Peter as well, but since I'm not knowledgeable about (digital) photography, I decided not to participate in your conversation.
Interesting read, that's for sure.
Whether or not the with the kit supplied jig is being used, it remains a rather challenging build and I am looking forward as to how your "jig less" build turns out.
Regards,
Johan.
Hey Piero,Hi Johan,
I am attaching the last photo I took before leaving the "SwissLab" and reaching the "Italian Lab". In fact, I notice a deviation to the left but not more than 1mm but I think it depends on the gluing of the keel, and subsequent drying, when I mounted it. This doesn't worries me that much because I get it back when I put up the bulwarks.
As one of my great compatriot said ".. to posterity the arduous sentence ..."!
Cheers!
Hey Piero,
That doesn't look half bad!
Hard to tell though from this viewpoint if the hull is warped or not, but the proof is in the pudding; only once the hull is completed, one will be able to tell with certainty.
Your suggestion to use the bulwarks to correct possible deviations does hold merit, although I suspect the hull, with all the beam supports and beams in place, might be a little bit stiff already.
I hope you don't mind, but I noticed two items which might need your attention, see added picture.
I wish you many happy modeling hours!
