- Dec 16, 2016
Hi, As I mentioned in my last post am now on to the array of pipes that surround the boiler, there are rather a lot and they look like spaghetti spread around by a mad chef. This proved to be the most difficult part of the build, I have never been defeated by even the most complex rigging yet but this was something else! Once again the instructions were a complete joke and just left you confused; given the complexity of the layout a line drawn diagram would have been much more helpful. I’ve shown a picture the instructions, remember that these are only 7cm each and not clear and sharp.
I decided that I would just have a token amount and fit only the main pipes, the ones that were most dominant, not paint them but leave them in brass as a feature. I chose to do this as it was necessary to use the boiler itself as a former and guide to bend the pipes to shape and as there were so many intricate twists and bends the paintwork was becoming marked and the handling was taking the shine off, also drilling out the holes for the many clamps left some flaking around their edges. I had used low tack tape to hold the wire down as I worked along it but removing it lifted small areas of paint so it then had to be held in place with rubber bands, not ideal but it worked.
What you see in the photos is about half the amount of pipe work required but it looks ok to me as it is so I’m stopping there before I mess up. Hopefully the running gear when it arrives goes better.
