- Dec 11, 2021
Johan, It was time to go back home ...
Nice to see the adjusted waterways, Piero.Update 22/03
I had a little accident ... moving from one table to another, she decided to bump into a chair and drop to the floor ... Oh well, I'll do it later.
The work continues with the assembly of the decks and waterways. The solution is to reduce them in order to have everything at the same level
View attachment 297668View attachment 297669
And with the little damage on the front, you will be become a member off the club ‘Restoration during new construction’.
No, only experience expertise is sufficient.Thank you Peter! Is there any form to be signed to become an effective member?
No forms required, just pictorial evidence of the damage and the repair...Thank you Peter! Is there any form to be signed to become an effective member?
Parking assistance an option? Every respectable car manufacturer offer those options standard nowadays...a lot of modern yachts have a similar demage at the bow, because of the "parking" in slot in the marina - better term should be mooring in the marina
yes, but try to push the brakes on a ship during such a manouver - it is still moving several meters, mainly in the direction you do not wantParking assistance an option? Every respectable car manufacturer offer those options standard nowadays...
Always nice to see a planked BN hull with a personal touch of the builder. The vaulted planking at the port side at the front is a good example of this. Well done, Piero.Here I am again with the latest update, my friends!
So, I finally finished the planking of my BN. It seems to have turned out well. Now begins the sanding part and then the painting. I reversed the sides of the planking because the side chosen by YQ did not work well in my opinion especially for the state of the frames. The portside is certainly more beautiful. So I closed the starboard side. Then I finished, and painted in white, also the part of the waterways on the deck.
I put on a Tamiya tape just to see the waterline level effect ...
Now some pics!
To the next update ...
