BS in Marine Engineering. It means I can BS my way through a ship model build.Did you say you have an engineering degree?
Says the guy who has a better looking hull and home made lines on his model . . .Too smart to be a dentist...
No way. Dentists scare me... like clowns and blimps do.Could be a dentist too
For some reason I find the fact that blimps scare you to be marvelously amusingNo way. Dentists scare me... like clowns and blimps do.![]()
. No wings? Sitting under a bag of explosive gases?
Sometimes filled with bad breath.explosive gases
Welcome to the DeAgostini club you will have fun. one of my german friends has it totally finished with a perfect result. DeAgostini is very popular in GermanyHMS Sovereign of the Seas - Bashing DeAgostini Beyond Believable Boundaries - by DARIVS ARCHITECTVS
Well, I just finished La Couronne and its display case a few hours ago, and swore that I would take a break before starting another project.
That didn't happen. On to Ship #2.
Research on building HMS Sovereign of the Seas started almost immediately. I opened Issues 1-15 of the kit and started pouring through their contents, eager to work on the one ship which is the greatest inspiration above all others. The first problem reared its ugly head immediately. The false keel assembly does not include the keel itself, ending at the garboard strake of planking. I could not use my multi-position keel vice that served my so well while building La Couronne! That meant that the base jig in the DeAgostini instructions has to be built and used. The keel is attached later in assembly, and I'm afraid that it won't be strong enough to use the keel vice, and one accidental bump on the hull will break the keel off, leaving the wrecked hull rolling on the floor. I guess I'll have to be careful.
Some more observations. This model has a complete lower gun deck, unlike Corel's La Couronne, so it will be easy to replace the false half-barrel cannons with complete carriages. (Don't look at me like that, Dockattner... You may take ALL the shortcuts you want! Not THIS sailor.) Because the kit instructions are scattered across 135 packages in magazines, the steps for assembling multiple similar items like cannons are also scattered, and there are no blueprints or rigging drawings to refer to that give you the complete picture of how elements like lines, decorations and other landmarks used in measuring are positioned, relative to each other and the hull overall. This is quite different than working from the two general arrangement drawings and seven rigging drawings that helps you classify and keep track of what you are working on, and where something goes.
Just to get something done, the first frame pieces of the bow were glued together, and some wood metal "L" brackets for making the base jig were purchased. There is still one more piece of wood to purchase before the base jig can be completed and the false keel assembled. Since I wanted to use those GORGEOUS Amati cast decorations on this model, the problem remains whether or not they would fit because the scales between the Amati and DeAgostini models are slightly different. Laying the false keel bulkheads on the Amati plans shows that they may actually be close enough to allow use of most of the Amati decorations. Each decoration, Amati or DeAgostini, will have to be chose based on how close to the Payne description of the decorations they are. Perhaps in some cases neither will work, and scratch built decorations will have to be made, which I do not have the patience, tools or talent to do. Carving is a slow, high risk task for me. Too much can go wrong. After all, I'm an engineer (Architectus in Latin), not an artist.
Many things will be replaced in this white metal casting, plywood ridden, arguably accurate DeAgostini kit. LET THE BASHING BEGIN.
It looks like somebody broke the sprit topmast, or it that just he camera lens effect?
This is NOT what the kit build would look like. This is the scratch built Italian made model that the simplified kit approximates, and falls short of:
Laparoscopic surgery on a ship. Amazing.
.. who else had to look that word up ?
I'm not. Got experience with that in hospital... who else had to look that word up ?
I do admire the work going into this build on all these extras, your canons have more work done on them and they will barley be be seen than my current builds canons that will be seen.Micro-update. Added the deck detail and wedges and coat for the mizzen mast. Wondering what to do next... maybe the beakhead bulkhead?
I will see them. I have a borescope!I do admire the work going into this build on all these extras, your canons have more work done on them and they will barley be be seen than my current builds canons that will be seen.
I imagine the satisfaction once this ship is completed will be huge knowing there has been plenty of effort in all the hidden details.
That’s awesome! Looks like you have one of the problems I have. These closeups show the tiniest specks of dust that I never see when looking at the ship with the naked eye.
Yes. Dust reflects bright light of the scope quite a bit. I would like to use ambient light, but the cameras in borescopes are not sensitive enough to create good images in very low light.That’s awesome! Looks like you have one of the problems I have. These closeups show the tiniest specks of dust that I never see when looking at the ship with the naked eye.
