The PS gun wale is now fitted.
I treated it with black ecoline twice and sanded in between with steel wool. Finally I applied a layer of clear coat and sanded again with steel wool. The frame tops which will be visible later I pretreated with ecoline.
The stern gun wale is made of an outside and inside part. In the manual these are installed in a much earlier stage but as I want to have the correctly lined up with the rest of the gun wale I fit them now. The parts which have to fit between the frames I removed as I will fit also an inner bullwark.
All are now in place.
On the isde I now have to make the bullwarks from scratch.
Dear Maarten
wonderful work,
I'm always looking on your work to learn how to do it right on my alert :) Okay
So much to read and look at. Magnificent work. I’m on a small holiday with only my iPad mini so I’ll look more carefully on the Mac at home.
It’s looking very nice and tidy, Maarten.
If other builders are not yet convinced of the beautiful application of (black) Ecoline, then I don't know what is.;)
With all the options like steelwool/(clear)coat, polishing/oiling etc etc.
(I didn't forget a few other users of course!)
Regard, Peter
Continueing on the powder room.
As promissed first I made some beams to carry the powder room floor, these are not kit parts but scratch build.
On top of the beams the deck is fitted?
I leave out one plank to see the construction below.
The wing platforms are replaced with just a small bulkhead in the wing, functioning as powderroom wall.
To avoid getting gun powder in any other space then the protected environment of the powder room itself the flooring was covered with lead and the walls with copper.
See below HMS Victory as an example.
I will create this with aluminium and copper tape.
The floor with aluminium tape which I sanded with fine steel wool before applying to give it a dull apearence.
I add additional small strips of tape which I pinch with a point to create the rivets between the lead plates.
The upper part is copper plated.
The powderroom bulk head gets the same treatment, lead for the lower part, copper for the upper part.
Dry fitting the parts.
Baby steps on the powder room.
To get in the powder room there is a small companion way from the upper deck.
It is locked between two deck beams on which a hatch is fitted in a later stage.
In the powder room entrance a door is fitted.
In the powder room you won t find iron fittings as these could create sparks, so all metal work is bronze or copper.
For my hinges I used copper wire hammered flat.
The inside of the door is reinforced.
And on the outside a brass ring.
To lock the powder room I made a copper lock with a brass key.
And dry fitting all into place, here you can also see the bar behind which the powder barrels will be stored.
Dear Maarten
I will ask for your help in locating the various parts in the fire dust room, except for the window I have already built. I'm having a hard time finding the numbering of the parts from the kit you used, I hope I do not bother you. Thanks
Dear Maarten
First I would be happy to verify the numbering of the 4 beams
Also how and to what extent you created the silver "bath" next to or under the window
I do not find this part that looks like a pantry / room / closet in parts of the kit. I would be happy if you would direct me to the right place or you created it yourself
And did you create the diagonal walls of the room and the light floor that you covered with copper / aluminum foil from the kit or your materials, what are the right dimensions / lengths and more
thanks a lot shota :):cool:
Hi Shota,
These are the beams.
All the other parts in the powder room are not part of the kit and created from scratch.
In the kit they only provide two platforms and a stairs.
You can just use scrap material from the kit.
The bath tub is also made from scrap wood covered with aluminium tape to simulate the lead lined tub to fill the cartridges.
See below the bath tub on board the victory.
The copper and aluminium are tapes.
Regarding measurements it is just tailor making to fit.
Hi Shota,
thank you very much for your answer and help :D
Now also the SB gunwale is fitted. The SB side will be plain wood, the frames will be open without planking.
The gunwale is profiled with a cutout razorblade. On the leftside the profiled gunwale on the right the default.
After fitting and finishing you can get a nice fit between the gunwale sections.
In the bow the frames are protruding the gunwale and are filed flush.
The complete SB side fitted.
For the inner bullwarks on the SB side I made bulkwark planks which I dyed with schminke which is a pigmented dye.
After that I sanded them with steelwool before fitting. Finally I will finish it with a layer of shellack.
Next is the deck planking
coming along very nicely. Looking forward to the deck planking.
