Great job Johan!
Thanks, Dean, though not entirely deserving... See my next post.Great job Johan!![]()
Hi Johan. TheHow time flies when you're having fun, or in my case when you run into unexpected issues.
About a week ago I completed the starboard planking of the hull and, If I may say so myself, it really looked well. Also the port side, which I than had planked as far as the starboard side, looked very promising.
So, optimistically, I ventured south, towards the keel. The first planks went on smoothly and all went well until I had to navigate "kaap de Goede Hoop", or, in this particular case, the transition to the deadwood.
That's where I discovered that my earlier beveling of the frames was sub standard; I could clearly see and feel a dent in the planking. What was worse, I was already upto five planks down, before I fully realized what was going on. First I thought about removing the affected planks. After trying that on the last plank, I quickly abonded that idea; too much risk of damaging a large number of frames, plus the removed planks would be next to unusable. Second option I considered and even tried to implement was to put some waste planks together and to file and sand that to size and thickness. That was an idea for the waste bin; I couldn't get it right, neither in terms of thickness variation, nor in the correct size, nor in esthetics. The last point is somewhat moot; the port side of the hull will be painted...
After disregarding the first to options, I went for the option to use a filler...
The next plank was attached, using shims on the frames 46, 47 and 48. The thickness was established by letting a plank touch the higher frames to see which frames were the culprits and to establish the required shimthicknesses. Once this plank was in place I could apply the filler.
After seemingly endless hours of measuring shims and planks, sanding, filing, checking I was able to complete the planking of the port side.
Unfortunately, it's far from perfect, but I decided to continue with what I have.
For a potential next build I would approach the char removal and frame beveling a little differently; the inside of the frames close to net shape and the outside of the frames well outside of the mark lines and use those lines as references during beveling. Furthermore, check once, check twice and check once again, even when you think your beveling is okay.
(Note to self: stay away as far as you possible can from pré-twentieth century sailing vessels with their blunt bows and sterns.)
The dent filled:View attachment 326024
From another perspective:
The port planking complete, pré sanding:
Thanks Dean,That’s unfortunate Johan…but as Peter said, if you are going paint, then the filler is ok. However I would suggest after sanding to the final profile, that you put light grooves with an xacto knife to simulate board edges. Otherwise the filler will still be noticeable. I would try using tape to extend the edges through the filler and follow that with the blade. Then once painted, it will still look like a continuation of the boards.
That looks good, Johan. Her lines becomes smooth again.Applied wood filler and sanded the port side for a second time.
She ain't looking half bad...
View looking fwd:
View looking aft:
As usual, your Admiral is rightStained the starboard side and applied one coat of clear, semi-gloss varnish.
I asked the Admiral for input on the finish of the starboard side; I wasn't even given an alternative, this is what it has to be.
Also reinscribed the plank lines of the upper part, holding the scuppers. Although visible, it's not as pronounced as I would have liked. I followed both Dean's and Peter's earlier given advice on the filled port side, but I didn't dare trying to follow the same line thrice...
As usual, your Admiral is right, Johan.
I’ll wait a couple of days before deciding.But maybe they'll add a little more once the stain is completely absorbed. That took me a few days too.
Very tidy planking work JohanApplied wood filler and sanded the port side for a second time.
View looking fwd:
View looking aft:
Good afternoon, Johan. Oh Boy. That must have been a sinking feeling when you saw the planking. Your fix is looking good. Just shows how this hobby throws these curve balls at us. I do think your admiral got it spot on. The starboard side is beautiful. Cheers GrantStained the starboard side and applied one coat of clear, semi-gloss varnish.
Very tidy planking work Johan![]()
Nomad, Grant,Good afternoon, Johan. Oh Boy. That must have been a sinking feeling when you saw the planking. Your fix is looking good. Just shows how this hobby throws these curve balls at us. I do think your admiral got it spot on. The starboard side is beautiful. Cheers Grant
