**VIEW THREAD HERE** |
Hi Heinrich,Just superb! Super-look on those gratings, Maarten! I can't wait to give the Clou a go on the Oak.
I will try to build up the tension.I like your "needle-nails" of the grating very much
Can you please shortly show us the "needle"?
Wow, looks marvelousNext is my scratch build addition. The forward and aft bullwarks are planked inside and outside.
The forward side.
And the aft side.
For the outside I am inspired by the contemporary painting of Alert with the painted friezes.
To do this I use a technique of transfering a print to wood.
I use a hobby lacquer and put a layer on the plank and let it dry.
I prepared fitting friezes and put a thick layer of lacquer on the printed surface.
Put a layer of lacquer on the wood also and glue the image on top of the wood.
Let the glue dry, you see the backside of the paper.
When dry you wet the paper and carefully start rubbing it away using plentyfull water.
When the paper is rubbed away the image becomes visible.
Now cover it with lacquer, I use multiple layers of schellack.
My first idea was to highlight accets with oil paint put I don t think that is needed.
The friezes are fitted.
And an overview.
