HMS Blandford POF by Keith [COMPLETED BUILD]
Beautiful work, Keef. One can only imagine what that is going to look like with your beautiful finish applied!
it's looks beautiful , well done Thumbs-Up :)
Thank you very much my friend. l'm really pleased you like it. l also am very pleased with the result so far. Everything seems to fit and l'm really enjoying this amazing kit
Good morning Kef, I ask, shouldn't the headers of the planking happen between the frames but above the frames, the under-beds are not assembled and from Kit? Thanks
Hi Frank. Really sorry, but l am not sure what you are referring to in your question. Sorry. All l can say is the deck is built according to the drawings supplied with the kit and so far it is fitting (amazingly) exactly as it should. At least, if l have interpreted them correctly.
Kef, it doesn't matter, it's the translation that doesn't make us understand, but, Thanks for answering me
I actually bought this ''building slip'' about 7 years ago. l believe it is from Billings Boats. lt is adjustable to fit any size hull. lt would be extremely easy to make one though. l could take some photos and give dimensions for the parts if you wish
love to have the details of the rig you have set up for the keel suppoort
Hi Keef,
What Frank means is that the joints of the planks should meet on top of a frame and not between two frames.
Actually I think for the outside planking of the hull that is true, as you need to water tighten the joint but on the inside ceiling of the hull that is of lesser importance. Actually the inside ceiling was not caulked.
bet you didnt take the exact measutement for the top of the keel post to part %a the top ofthe transom
Ifb so can you let me
know
THANKS
You can take this measurement and all measurements you will need from the scale drawings of the hull side and top views which are provided with the kit
Hi Keef,
Sorry Maarten, if there's nothing underneath, how do they nail? (Fixing)
Looking very good - you are producing a very nice ships-hull my friend! Thumbsup
No.15 is this one, or (red arrow)?
Yes, this is the necessary learning curve.....
but I think it will be not a very big deal. The frames are long enough and flexibel, so I am pretty sure, that you can relatively easy bend the top of the frame 15 parallel with the others. I guess you have to fix all ends of the top timbers temporarely with a strip (green line) before you are able to make the internal sanding inside the hull.
BTW: Did you read my last question in post #84?
ive got the same problem (Different frame) but it can be pulled in and i guess (Hope!) that when we fix the filler pieces it will get it all ship shape and Bristol Fashion
Ive glued most of the frames 2- 49 ! will do the others when my back allows me Cant do cant frames on the bow till i get a new no one frame which has gone somewhere - often loose a tiny piece of a model but never a complete frame
