Thx gents for your input.I love those carvings, and they look great!
I have only one purely aesthetic input, which has no bearing on historical accuracy. It may just be the angle from which the photo was taken, but there seems to be a lot of empty blue at the top of the lower transon. Since there is fancy work (leaves of some kind) below the carvings on the upper transom, and fancy work (more leaves) below the windows, perhaps and band of leaves at the bottom of the lower transom (below your superb carvings) would fill in some of that space and tie all the carvings together visually. Again speaking only from an artictic perspective...
Thx Paul,So beautifully done Maarten. I've become a believer in these inks. Have you tried mixing them to create custom colors? I suspect the line of available stock colors is not extensive...
A nice tight version of the railing, Maarten.My Alert is nearing it s completion, so working on a lot of small details. Today it is the railing on the stern section.
On top of the frame timbers there is a small railing fitted.
To fit these into the frames I have filed some slots into the top of these frame tmbers.
The railing itself is a laser cut part.
Fitting the railing into the slots with pva and clamping them.
After drying I sanded the frame timbers flush with the railing and fitted a cap of some scrap cherry.
After some filing and sanding the caps are one piece with the frame timbers giving the impression the railing is enclosed by the frame timber.
On the PS side the same procedure only afterwards coloured black with ecoline.
And the result after some steelwool sanding.
Brilliant!
You said it Martin. That means a lot of practice.Thx Tobias, you will have some carving to do on your Amaranthe.
