@dockattner, yup I had all the information on how to do that step and still got it wrong.
Yup. I guess it comes down to “measure three times and cut once”. I should have really paid more attention, after all I have the fitted the frames three times and never paid attention to the frame fit at the stern. It wasn’t the lack of building instructions all the information is available.That is not serious my friend. Some hot water, a brush and off you go!
sounds like something my wife says about me...@dockattner, yup I had all the information on how to do that step and still got it wrong.
Good evening Jan…you not alone here- I promise. Cheers Grant@dockattner, yup I had all the information on how to do that step and still got it wrong.
Good morning Jan. Awesome post. Even the frames are aesthetically appealing.Clearly not an easy build (I see you seem to gravitate that way- WB and allThe ”Re-Do” was a success. Lots of hot water to break the glue bonds, then let the parts dry.
A note for the “San Bartolome” builders. Frame 23 needs a bit of work to properly fit onto the keel.
The arrow points to the “guide” hole that aligns the frame with the keel. That opening needs to have the bottom cut out another 1-2 mm to line up correctly. The build plan doesn’t show that but the build video does.
Assembly made up of frames 22 & 23 and other parts mounted and fixed in place.
I’ve found the best way to proceed is to study the instructions, watch the appropriate video, dry fit the parts and repeat that process before any glue touches wood.
Indeed that seems to be the way it is. This build is quite the challenge, it looks simple on paper and in the various videos, but there is a wee bitGood morning Jan. Awesome post. Even the frames are aesthetically appealing.Clearly not an easy build (I see you seem to gravitate that way- WB and all). Cheers Grant
Good point on the grading.Very complicated indeed. Jan, check your grating. I do not know if it is fully assembled, but what you have shown there, does not look right. It almost looks as if the longitudinal spars sit on top of the cross-length ones.
The top down view doesn't show the convex curve of the actual assembly. It also looks much better when all the "char" is sanded off.Thank you for that clarification, Jan. You have assembled the grating correctly. It just looks strange directly from the top.
Good morning Jan. This is a complex construction- so many parts just to create the frame. Gratings looks good. Cheers GrantGood point on the grading.
The instructions on page 83, I wasn't sure on the assembly since it looked odd to me. BUT.....
The assembly.
Thanks Uwe. I'll have to work on that.Yes - the top of the grating should be sanded down, that the red and the green areas have the same top level - like in the front
so the complete top of the grating should be sanded
The assembly.
