The later steps of the build include a number of fun things to work on!Fancy dancy!
Good afternoon Jeff. Details, details and some more….excellent. Cheers GrantHarpoons, lance boat hook and boat spade iron were made using dowel, thin brass rod and brass heads. Several different types of heads for the harpoons and the heads were soldered onto the rods. The pieces were rigged as per the plans.
View attachment 341577View attachment 341578
Waifs (flags) were made from some red fabric I found in a rag bag found in the house. Waifs were used to mark the location of the whale so it could be found later if the whaleboat had to leave for some reason. These were rolled up until used.
View attachment 341579View attachment 341580
Thanks, Grant. Details are one of the reasons I chose to build this kit.Good afternoon Jeff. Details, details and some more….excellent. Cheers Grant
dittoWow!
Would black card stock work? The brass and wood appear to be a little thick?Paddles were made in a similar manner to the oars. The blades are laser cut and the dowels for the handles were opened with a saw on the end to slide onto the blade.
A bomb lance was made from a toothpick and card. This device fit the gun and had rubber fins that folded to fit into the barrel.
Four mast hoops are required for the sail. I tried making them out of wood initially but broke each of the ones I tried to make so I made them from scrap brass sheet. They were wrapped around a dowel to the correct diameter and the ends solder together. I painted them brown. I think I will have another try at making wooden hoops since I don't really like the brass ones.
View attachment 341972View attachment 341975
Considering the scale of this model is 1/16, I really don't think the brass is over sized (at least not by much). The pieces have to be bigger than the mast in order to slide up and down with the sail. The book with the kit suggests brass strips of 1/32" wide and mine are closer to 1/16" so, possibly oversized in the vertical direction. I have some time before I am going to need these, so I am still thinking about them.Would black card stock work? The brass and wood appear to be a little thick?
Thanks, Paul. Possibly a mounting method for your Esping?Love it, Jeff!
Indeed. On my Vasa I neglected to think it all through ahead of time. The 'open format' of these little boats requires some ingenuity.Thanks, Paul. Possibly a mounting method for your Esping?
The bow and stern sheets in this boat made it fairly easy to hide a small block of supporting wood under them. (https://shipsofscale.com/sosforums/...odel-shipways-1-16-by-jefft.10753/post-272123)Indeed. On my Vasa I neglected to think it all through ahead of time. The 'open format' of these little boats requires some ingenuity.
Stunning JeffToday I present the mounting of the whaleboat. The plans and booklet describe two different possibilities, the simple use of brass rods and tubes along with the plans to make davits to hang the boat. With the right tools the davits would be an exceptional way to display the build, however, I took the simpler route. I had previously drilled pilot holes in the keel of the boat and placed supporting blocks inside the boat. I drilled out the holes to the required size and inserted & glued the brass rods which were cut to the length needed.
View attachment 342287View attachment 342288
The base is 1 x 4 x 1/2" pine. Holes were drilled in the base after alignment with the brass rods of the boat. The tubes were cut to the desired length and glued in place. The board and tubes were painted satin black.
View attachment 342285View attachment 342286
The boat is placed on the base with the rods going inside the tubes. A length was selected so that the extended centerboard was about 3/4" above the base. I will be displaying this build on a 6" wide self, so this mounting method works very well for my space.
