- Jan 9, 2020
As part of an ongoing finishing process of the hull (while waiting for the glue to dry during the planking of the little boats), I have started sanding certain identified areas with 1000 and 2000 grit sandpaper and then re-applied the stain. Slowly but surely the finish is getting smoother and smoother and more in line with what I had in mind with regards to how I wanted the finished hull to look.
The stern still requires some work on the edges of the border planks, but this is all falling into place.
I don't know if there is such a thing as a perfectly symmetrical hull, but this is as close as I am going to get to that.
Work on the lifeboats has now progressed to a point where the hull is strong enough that I can start using clamps. This does not speed up the process, but it does negate me sitting for an hour applying finger pressure to a freshly laid plank.
