Nikitin San Bartolome 1584 A.D. (Kit #35)
A good day in the shipyard, three pieces more and the main deck is finished . (The build crew shift was over and we all headed to the Sports Bar to watch our favorite NFL football team)4CDA3DFA-F308-4299-90BA-5EC7E3ADD676.jpeg
I love the alignment of planks and tree nails. What do you guys think?
The building progress has reached a milestone. We are at the start of Chapter two in the instructions.
NOTE: The two pieces in the upper left corner marked 80L and 80R, I think should be 77L and 77R.
I had to move the hull to my adjustable workbench, sitting in my Office chair and working at desk level for any length of time proved to be to much. To give you a hint to the size of this build check out the tape measure at the bottom of the jig and the dimensions on the work mat. The width of my worktable is forty inches.
The start of planking the deck is next. I’m trying to decide wether to pre-stain the planks with locally available paints or wait and order Pavel’s and the follow his paint video.
Wow there is a lot going on in that frame, it looks like a real ship is taking shape, watching this build with interest how it all comes together.
A good day in the shipyard, three pieces more and the main deck is finshed. (The build crew shift was over and we all headed to the Sports Bar to watch our favorite NFL football team)View attachment 342842
Good morning Jan. Personally….hmmm.ROTF.Nope Jan, they are perfect. Beautiful deck for sure. Can’t wait to see it stained/clou’ed/poly’ed. I hope your NFL team “gave you” a pint or two in celebration. Cheers Grant
I think it looks very good, Jan. You can be well pleased with that.
I am pleased with the outcome. The last two pieces are a bit tricky. There will be a wee bit of sanding, filling and diddling to get them fit properly around the frames and still keep the tree nail alignment.
The STAIN, that’s going to be the question. I will be experimenting with that during the week. I have Oak and Walnut in various shades and want to see if I can duplicate Pavel’s method to get his Antique look.
I went with a middle of the road brown but it is a little dark for my taste so I will be doing 3 different shades. I found that a light amber color ( minwax #210b - golden oak ) really changes the wood to a golden brown similar to the base color as pavel's . Definitely do some testing, I believe the wood is beech but not positive on that.
Post #14 on page 1 of my log is golden oak golden oak stain on hull planks
Wow, a great day to be in the boatyard. The temperature outside is 32F/0C, it’s raining and the rain is leaving coatings of ice on every surface it touches. A good start for our season number four (Winter).
”It’s off to work we go” :p ( Caffeine high, three cups while catching up on SOS logs):p
The Main deck planking has been completed. The final plank edge piece on the Starboard side fit exactly, the Port plank edge needed to have indentation filed at a couple of frames to get an exact fit.
I’m pleased to note that taping together and dry fitting the main deck planks worked out great.
I’m continuing that process with the Fore deck planking.
The edges of the planks at the bow need to trimmed, but overall this process allows me to see how things fit.
Good going Jan. I like the color of the deck planking and it looks like really good quality wood.
I have no idea of the type of wood, but the quality is very good. I’ll probably use the same technique of taping together and dry fitting for the Poop deck planking.
Yup, I did it. My Fault. I have admit to a slight Re-Do. Somehow I got this assembly backwards and a wee bit higher on the frame than it should be.
The door opening should be on the left, the bowsprit hole doesn't line up with the hole in the frame. Hot water, a brush and some patience and .....
we are ready to correct my mistaken..
Glue it all back the right way once the parts have dried.
I noticed the problem while doing the prep work for laying the planks on the Fore deck. I was scratching my head as to why the first plank was laying at an angle across the frame tops especially at the bow when I noticed the height difference in the frame assembly. Then I noticed the Bowsprit holes weren't lined up, well the rest is now history. "My Bad":rolleyes:
The Re-Do.
The assembly problem corrected. Which brings up another assembly that was glued together in the first part of the build.
This assembly is the foundation for the mast and the bowsprit. I thought it would be a good time to set it in place before the Fore deck was planked.
The progress continues after the “Re-Do”.
A little prep work was needed before laying the planking. A cross piece needed to be added to fill the gap in this frame.
Part 58, the ”wall” needed to be temporarily clamped in place.
The first plank aligned with the mast opening glued and clamped.
After gluing one more plank on the Port and Starboard side, a temporary backstop was clamped in place to help align the planks.
I think without the information provided by Pavel in his YouTube video, a novice builder like me would have a bit of trouble figuring all this out.
Pavel Nikitin Video #14
Good morning Jan. Redo sorted. This does not look easy. So many supporting and foundational little parts to remember. Must be super fun tho. Looking very goodThumbsup Cheers Grant
It certainly looks like you're having a great time - and your progress is great as well!
I think it's the sheer size of what I'm working with that's making this build so great. Pavel's videos of the various stages of the build are excellent. They're show a lot of little bits that Pavel does that aren't on the isometric instruction drawings. I pop up the appropriate video on my iMac and then find the parts that go with that stage of the build. I constantly refer back to the video as I work.
Indeed I'm having a great time. Lot's classical oldies playing in the background, genuine high test Duncan Donuts coffee and lot's of odd parts to glue together.
Dear Jan
Wow, you are doing wonderful work there. it looks like a real ship is taking shape, watching this build with interest how it all comes together. Okay Thumbsup :)
