- Sep 3, 2021
And a first aid kit...I will bet it wasn't your first or won't be the last time that happens. I always keep debonder near by will working.
Exceptional modeling. And as far as the mislocated frames go; who's going to tell?Well, I unexpectantly ran into a few free hours for modeling today so I was able to wrap up the framing - or nearly so.
I still need to add in a bit of framing at the bow (something that would function like a breasthook), but it needs to be placed above a seat and I haven't established the vertical position for that seat yet.
For the record, I went back and looked more closely at some pictures I have of the real esping and realize I did several of the forward frames incorrectly (misinterpreted the line drawings). The good news is those frames will be covered by the same seat I just mentioned so no one will know (well, except for you guys).
This little boat is really fun to work on!
There is an topic that shows you how to build one. Easy to do....would also need a thickness sander to create this custom sized piece of wood which I don't have. Hmm...
For a first time scratch build ……. Not bad at all, Paul.Thank you kindly, friends, for the encouragement and likes.
I discovered another framing error before I went to bed last night. The straight pieces that sit on the flat floor of the boat between the curved frames should be thinner than (about half the height of) the frames.
I am growing in my appreciation for what it takes to do accurate scratch construction. You cannot just look at one drawing if there are other drawings of the same area of the ship from another orientation. I was only using the overhead view and neglected the side view. That seems obvious now but apparently wasn't obvious to me three days ago. Careful study of ALL available information is necessary.
I realize how elementary that must sound to experienced scratch builders - but to me it is more revelatory. I'm a detail guy and I missed something clearly evident if I would only have paid attention. Am I going to pull those pieces out? I don't think so. It would not be easy to do that without causing all kinds of collateral damage (this boat is smaller than it appears on the photos). I thought about sanding or filing them down, but I don't think that will turn out so great - better to keep them flat and clean.
I would also need a thickness sander to create this custom sized piece of wood which I don't have. Hmm...
I'm not really dismayed by this discovery - it's all part of learning a new hobby. But I wanted to share this post so others can learn alongside me.
Oh, in my defense, I don't have ship plans in the way they are ordinarily available (or you might be thinking of them). I would describe the line drawings I have as archaeological rather than for the purpose of building something. Nevertheless, a lesson learned (and now shared).
Onward!
Th
Onward!
Well Doc, if you stay on the good side and send a letter to Santa and really believe, you never know what could appear under the tree in a month from now.Thank you kindly, friends, for the encouragement and likes.
Onward!
Keenly observed Kurt. As I understand it 1:64 is a standard / traditional scale for models and miniatures (1:48, 1:64, etc.) and I have a suspicion my Vasa kit is actually 1:64 (with 1:65 on the box being more of a marketing thing). Even if I'm wrong I can assure you that my ability to draw pencil lines and measure introduces more than enough error to make the scale of my work more of an estimation than an engineering certainty. I should probably change the title to 1:60 to 1:70ish..Hey Doc, just noticed that there is minor difference in scale between Vasa and this boat, 1:65 vs 1:64, is there a reason you didn't build to same scale as the Vasa?
Great segue Paul. I was a "good boy" this year and Santa/Admiral came early, literally yesterday! All I can say is, it is worth every penny. Accurate over the 400mm length of the board to 1-2/100 of a mm.Thank you kindly, friends, for the encouragement and likes.
Onward!
If I had Stephan's skills I might try and build my own. But if I built one with my real skillset (not imagined), you would not let the kids or the pets get close to it, let alone my fingers!!
Ken,Great segue Paul. I was a "good boy" this year and Santa/Admiral came early, literally yesterday! All I can say is, it is worth every penny. Accurate over the 400mm length of the board to 1-2/100 of a mm.If I had Stephan's skills I might try and build my own. But if I built one with my real skillset (not imagined), you would not let the kids or the pets get close to it, let alone my fingers!!
View attachment 343320View attachment 343319
I wondered about that gap. I assumed it was a result of ‘sagging‘ of the raised boat. I’ll want to correct that mistake. Do we know if the sheave was wood or metal? I assume the pin for that sheave passed through both cap rail extensions? I guess I didn’t see any holes there. Hmm. Thanks for pointing this out Peter.Looking great!
Don't forget the gap for the sheave at the prow on starboard side!
Cheers,
Peter
