A quick post this morning. The Admiral is in the middle of decorating the house for Christmas and I’ve been volunteered as the primary work crew. But I’ve managed some progress.
I’m currently working on the Poop Bulkhead.
The Bulkhead frame.
View attachment 344509 View attachment 344513
This part is easy to assemble wrong. As
yfish noted in his log the uprights have an indentation with a slope at one end. That end is glued into the top piece and provides the bulkhead with the correct form.
Pavel’s video for this part of the build shows an unique method of assembling the six wall panels for the bulkhead. He assembles and glues the bits to pieces of thick card. I thought about that a bit and came up with this method.
I made a copy of the build instruction. Copied that onto some heavy construction paper.
Placed and glued the bits on the construction paper.
Then cutout the finished panels from the construction paper backing.
Phew, a long winded explanation for a small project.
The whole assembly will now wait to be painted.
Painting, I don’t own a airbrush, have no Idea how to use one and need some help with that. What should I looking for as far as airbrushes go. Gravity feed, little screw on bottle, .3mm, 3.5mm. compressors? A lot of information out there and I don’t understand any of it.
Got to go I can hear the Admiral calling. Decor time!
