Roter Löwe 1597 by Ondras71 - scala 1/60
Cześć Ondrej, byłem na mistrzostwach Republiki Czeskiej i widziałem na żywo Twój model. Złoto zupełnie zasłużone, model robi niesamowite wrażenie, że dopiero powstanie. Jesteś bardzo silny. Gretingi robią wrażenie, cały model jest genialny. Szkoda tylko, że nie mogłeś przyjeżdżać do Karlowych Warunek, atesty mistrzowskie w mistrzostwach do wolnych dni, i których nie poznajesz. Pozdrawiam i gratuluję. :)
Hi Ondrej, I was at the Czech Republic Championship and saw your model live. Well deserved gold, the model makes an amazing impression that it is yet to be built. You are very strong. The gretings are impressive, the whole model is brilliant. It is a pity that you could not come to Karlove Condition, championship certificates in the championship until your days off, and which you do not recognize. Regards and congratulations.
Thank you all very much for the wishes and likes friends..:)o_O Also, thank you for the explanation of Naviga's categories, I didn't have the strength to do it with the illness..Cautious
Continuation with the production of "belaying pins". The form has been modified a little, the pins are now smaller..
Comparison with the old one, a total of 58 pcs..
Pins on the bow. I have to darken them to make them stand out..
great progress it's looks beautiful, I'm not surprised that you won the gold medal, as far as I'm concerned, you're a master craftsman in the field of models and in general, well done friendThumbs-Up
Congratulations Ondras.
Superb build.
Thank you very much friends, I appreciate your words.;)
I still work with breaks. Other Small Staghorn harnesses..
More work on the largest triangular Deadeyes. Homemade production is literally done by hand..o_O
I found new options for the MF 70 cutter..Thumbsup
side groove..
rounding of edges..
Test with 0.52 mm cable..Explosion
Such precision Ondras! So impressive!
Top, very beautiful work, Ondras. Thumbsup
Don´t mix them - very accurate as usual
sometimes I have also the feeling, that I repair more than build something new ;)
Thank you very much gentlemen. Thanks for the like!;)
Finally, clamping deadeyes called "chains deadeyes" on the main mast..Explosion
General view..
Now I have small deadeyes waiting for me on the mizzen mast..o_O
I made the last two sizes of small 4mm wide deadeyes. Again, a system of glued plates and machining at once.. o_O
Created a tool for a milling cutter for the production of a 0.4 mm side groove..
All deadeyes after waxing.. Explosion
I wish everyone a lot of success in the new year 2023, a lot of peace in modeling and, above all, health!
Thank you all for the likes!
:imNotWorthy:
Deadeyes fittings for besan made of wire 0.4 mm..
I ran into another stupidity in the plan. From a layman's point of view, deadeyes cannot be placed directly on wales. The ropes would break against the broad stern.. o_O
I measured the width of the channels..
Channels again secured with steel pins..
Deadeyes attached to the hull..
Hi Ondras
You are not correct here, my friend.
The Willem Barentsz's deadeyes were placed directly on the wales without any chainwale.
Hi Ondras
Hello Heinrich. The fit of deadeyes is limited by the shape of the hull. My ship has to have channels.
There are also narrow channels on the Duyfken and Barentsz ship replicas.
Although they weren't on the build model either..:rolleyes:
