You're always good at finding values...where did you order the clamps from?
I have several Japanese saws--superior in so many ways to most western-style saws.Today I gave myself a gift of some tools.
Japanese pull saw Dozuki 240 mm J-WD240, blade 0,3 mm 25 tpi
3 pair of Japanese serre joints 300 mm
and some sanding linen 400 and 600 grid
Glue a piece of sanding paper on the inside of the clamp to avoid slipping.They just don't have any holding power.
I wasn't referring to their ability to grip objects. When you start to tighten the screw to apply pressure the clamp just slips on the bar because the holding screw and rod are soft brass.Glue a piece of sanding paper on the inside of the clamp to avoid slipping.
I tried them, no problem with them. These are quality serre joints, made in Japan.I wasn't referring to their ability to grip objects. When you start to tighten the screw to apply pressure the clamp just slips on the bar because the holding screw and rod are soft brass.
I'm glad then that you are having good luck with them. They do come in handy on some things, but they did not meet myexpectations.I tried them, no problem with them. These are quality serre joints, made in Japan.
I bought the Syren jig but didn't particularly like the way the sprockets meshed, so I too made another one myself and substituted metal gears I bought from Amazon. Works really well! Each sprocket was installed with ball bearings (seen in the picture).I was going to buy the Syren Servo-Matic but they were out of stock and I didn’t want to wait so I made one… works very well And didn’t spend but about $6.00 on some lamp hardware
View attachment 346909View attachment 346910View attachment 346911
Great work! I really like your “dry dock” cradle. I’m assuming you custom built that? Also great work.I bought the Syren jig but didn't particularly like the way the sprockets meshed, so I too made another one myself and substituted metal gears I bought from Amazon. Works really well! Each sprocket was installed with ball bearings (seen in the picture).View attachment 347023
