**VIEW THREAD HERE** |
Hi Donnie. Pulling a toothpick all the way through a draw plate to the desired thickness is almost impossible. I only 'turned' a few millimeters of the tip to the desired thickness:Old school treenailing of the deck. I don't have a draw plate. I have heard good and bad about them. If anyone can convince me of which one to buy and an example of how to use one, I might consider it. Toothpicks are getting kind of old doing it this way.
The reason is that I have a friend near to me that I went to his house as he is building the Le Feuron - he showed me his draw plate - but he admitted that he could not get the treenail to the size he wanted because the draw plate continues to either break the treenail or not make the treenail correctly. Maybe his brand of draw plate - I am not sure.
Hello Donnie, I have found that cheap drawing plates also do the job, it depends on the sanding whether the drawing plates are good. When planking the deck with treenails, I first sanded the protrusions flush with sandpaper and then worked with the drawing plate, with little pressure so that the nail does not tear (fringe formation), then polish with steel wool.
I saw your posts, Tobias. Now we have clear the difference between Draw- and Scrape Plates.OK I think I misunderstood something, sorry I thought Donnie meant the drawing plate for smoothing the deck. Sorry my mistake
Yes, Peter, you said it.I saw your posts, Tobias. Now we have clear the difference between Draw- and Scrape Plates.
Regards, peter
I agree with you Uwe. That's why I used the draw-plate from the 'back side':An often mistake is also, to use a drawplate which is usually used by juwelier makers - these drawplates are used for silver or gold wire and press the wire to a smaller diameter, so the material will not get cut away, but pressed and the wire will get longer.
We need drawplates which really cut the wood material away - somehow scraping the oversize.
Another mistake is often to jump over diemeters - you have to pull the wood through each size, maybe sometimes 2 or 3 times the same size
One of the best drawplates is sold by Burnes Maschines - highly recommended
