He has a build log on SosThere is a guy that completed the Santisima Trinidad cross section with a weathered look. Here is one of his videos for the deck. I am sure if you youtube'd this you could get the rest of his videos.
**VIEW THREAD HERE** |
Definitely not easy to apply.So, he used graphite. That can be risky as in the fact that if you start and you do not like it, then it would be very tough to get sanded off.
I love antiques! lolZoltan said this is a type of oven or fireplace. I think I agree. I used a black wash on the inside. It might look kind of simple, but there are a lot of parts to this tiny thing.
AND MANY YEARS AGO !!!
Hi Donnie, you can check this method by D. Banton (the link is a pdf file, i didn’t know hoy to embed it directly here): https://www.google.es/url?sa=t&rct=...0d74b3bbc3e8&usg=AOvVaw1wA8kpdn6hyjJbAtQVEJdpThe only thing I wish that it looked more used and aged. Not sure how to do that.
Hi.can I ask you a question.the translation into Russian sounds like ink for wood.what is this ink? Just plain paint or not?Hi Donnie, you can check this method by D. Banton (the link is a pdf file, i didn’t know hoy to embed it directly here): https://www.google.es/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwjQpu6G4Lj8AhW0CrkGHe-UAfgQFnoECBoQAQ&url=https://www.foromodelismonaval.es/download/file.php?id=130176&sid=b52ea5bf8b3375bd78980d74b3bbc3e8&usg=AOvVaw1wA8kpdn6hyjJbAtQVEJdp
he applies it to all his works and the results are quite astonishing! Is in spanish so if you need help translating some parts let me know!
cheers!
Это тушь, черная или другого цвета. Мы ипользыеем тушь для цернения, она хорошо пропитывает поры дерева и оставляет птотный цвет.Hi.can I ask you a question.the translation into Russian sounds like ink for wood.what is this ink? Just plain paint or not?
That's just India Ink. Used by calligraphers and hand inking techical drawings with pens (ie Rapidograph). A caution: it will soak into and follow the grain of most woods. Try it on scrap first.Это тушь, черная или другого цвета. Мы ипользыеем тушь для цернения, она хорошо пропитывает поры дерева и оставляет птотный цвет.
Да, это обыкновеннная тушь. Зовут меня, Дмитрий.Здравствуйте Дмитрий.Вас так зовут?если я правильно вас понял то это обычная тушь для перьевой ручки,так?
Hi Novichok, probably the spanish word tinta is a bit misleading in this case. What the author is meaning is wood stain of genizaro colour. I found the exact bottle (see image) but I believe it doesn’t need to be that same exact product (I highlighted the colour code), probably any dark wood stain would suffice (walnut type or similar) for this purpose. Hope that helps!Hi.can I ask you a question.the translation into Russian sounds like ink for wood.what is this ink? Just plain paint or not?
Beautiful work! What is that? Basswood? Birch plywood?So, this little guy was the most tedious so far (or by far). The brass pulleys (in my case) had to be sanded down to .39mm to even come close to fitting in the slots. Once I was able to get the pulleys in easily, then the rest was OK getting the brass pin in to hold them.
Drilling here is obvious, but what not be so is that I used a large End Mill to square off the bottom to make it flat. Note that the Pulley is setting on a parallel bar to keep it square too. I drill half way and turn it over and drill through the other half. It is ok to be off a few thousandths in the middle of pulley, but by drilling at the marked holes on each end, I am guaranteed the hole in correct position on each side.
As far as I understand, it is all Pear, Phil.Beautiful work! What is that? Basswood? Birch plywood?
