She makes that ship look massive
     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
It’s 32” long x 8” wide, so while planking the hull it seems massive!She makes that ship look massive
Well it is a Danish Norwegian ship, so that has Viking roots…there could be a story there.AAAhhh! But to do that, the ship that you build has to be steeped in controversy and mystery! They don't come any more mysterious or controversial than the WB!![]()
Thanks Paul! It certainly has been a lot of work to get this far! I couldn’t tell you how many boards have gone on…lol. But we know the most work is getting the decks in and hull planked. After that, it is all eye candy!Looks nice, Dean!
Your planking looks just perfect, incredible!This weeks progress update…
The keel has been finished on the starboard side. Port side bow keel piece is on the work table for reference. After planking there are 3 pieces added to the thickness of the keel. 1 at the bow, 1 at the stern, and 1 plank in between.
Then I did final sanding and painting of the white below the water line on the starboard side hull.
Also I am making good progress on planking the port side hull. I am about 75% done.
It’s been a productive week!
ps - hull planks are 2mm thick x 7mm wide! Not the easiest to bend, but plenty of thickness to sand. I would have preferred 1.5mm thick x 5mm wide. I think that would have been easier to work with and probably more to scale. If I had to do it over, I would have purchased 5mm planks.![]()
This is not surprising me, Dean. She helped you the same way with your BN. With now more experience. Bravo!
I see two lovely girls
Thank you Johan! Trust me it is not perfect, but turned out good after sanding...lol.Your planking looks just perfect, incredible!
Thank you!I see two lovely girls![]()
Ditto. I am a great admirer of Deans woodworking skills. Cheers GrantYour planking looks just perfect, incredible!
Good morning Dean. Now I know why your ships look so good! I need a helper like that.
Thank you Grant!Ditto. I am a great admirer of Deans woodworking skills. Cheers Grant
Yes, she’s the best! Always wants to help.Good morning Dean. Now I know why your ships look so good! I need a helper like that.Cheers Grant
I think that from my side part of the 'long term memory'Yes, on the Bluenose too...
And on the Cazador as well!
