Wow! Excellent photos of a phenomenal build! Congrats Peter, you really have built the BN model to set the bar!
**VIEW THREAD HERE** |
Thanks for the compliments, Dean.Wow! Excellent photos of a phenomenal build! Congrats Peter, you really have built the BN model to set the bar!![]()
Sure, I ‘set a bar’. But please for all the others BN builders: it’s not THE bar and it’s not THE standerd, (or all the other nice qualifications I saw passing by.)
Please go on with the build of your BN’s and keep on posting in your build-log’s. For sure I like every build, because you are building. And when my build is inspiring you to raise your bar for a detail of a part, then that just makes me very happy.
Then we disagreeThis one is THE standard and THE bar period!![]()
Wow. I can look at these all day.With the ultimate intended result: The Pull-Apart-Model:
Her imposing bow:
Whereby you can now also see the inside-bottom:
A little zoomed in and with some details.
The front:
The Middle:
The aft:
With the open Main Cabin to look inside:
More to come ......
Have you thought how you will accomplish the joinery? Are you just going to depend on the brass corners to hold the frames together?Made a start with the showcase by collecting the necessary materials.
On the OcCre site I found these profiles:
They are 15x15mm / .59"x.59" with 3mm / .12" rabbets.
That was just a bit too thick. Put through the thicknesser at a friend of mine to 12.5x12.5mm / .49"x.49". Not much off but just enough to make it more slender. On the right there is 2mm plexiglass. The corners are still chamfered.
OcCre also had these corner reinforcements:
But on those coming up? It also depends on how that will look and how neatly I can make the corner joints.
Bought this from a large store for LED strips:
-3 meters of 2-tone white dimmable LED strip, 60 double LEDs per meter
-'controller'
-battery
I already had the remote control for the LED on the Robt. E Lee.
The LED strips can be cut every 10cm /3.94".
With the soft-tone LED's:
With the white LED's:
For my Bluenose that will be a rectangle of 80x20cm / 31.49"x7.88".
The LEDs draw sharply here, but gonne lie in the glass seam.
I fixed the LED strip on a temporary shelf to measure various sizes. I have to take into account the coupling pieces:
Schematically, an inner plate and the profile slats will be placed on the outside against the LEDs, so that a slot of 3 mm wide and 3 mm high is created.
The glass plates will fall into this, with the glazing bars resting on the corner pieces. Rubber blocks are placed between the LEDs to prevent the weight of the glass from resting on the LEDs.
I now have to measure these parts, taking into account the width of the LEDs of 4.9mm / .19".
-the base plate on which the LED strips are glued.
-the inner plate that will fall over the ground bond of the LED strip until just slightly over the inside of the LEDs. And protrudes 3 mm above the LEDs.
-the profile on the outside that falls in a similar way to just slightly over the outside of the LEDs, also 3 mm above it.
-the thickness of the profile on the outside is as high as the thickness of the base plate and the inner plate.
Anyway, still a lot to measure and puzzle.
Hi Daniel. The LED’s shine from the bottom upwards through the vertical glasses and will radiate slightly to the side. That will certainly reflex a bit via the top flat glass and hopefully give some extra lighting from above. That’s the theory …….Those Leds will make for a stunning presentation. Will you have any on the top of the display case shining down?
Well, Grant, my build-log is open every day 24/7 ……… You are more than welcome.Wow. I can look at these all day.
Hi Phil.Have you thought how you will accomplish the joinery? Are you just going to depend on the brass corners to hold the frames together?
Hi Jan. Hopefully, what was conceived in theory will come true in practice.As always I'm fascinated by you imagineering. The LED's are a nice touch,
Jan
It'll be beautiful. Glass or acrylic? Either way, it'll be better than dust huh? Looking forward to seeing pics!Hi Phil.
My starting point is everything mitered with double 45 dgr on all the profiles on all 4 corners. But that will require precise calculations for the dimensions of the glass that is in the recessed recesses. But I have all the time.
Have the brass corners come along just to be sure.
Thanks for this nice words, Mark.Simply magnificent work Peter! The photos of your unique BN photos are sensational and, naturally, you have set a bar in excellence that leaves the rest of us in the shade![]()
How can an elegant Bluenose that produced so little shade, cast it over so many Bluenose's from other builders?You have set a bar ……. that leaves the rest of us in the shade
Thanks, Dean. Hopefully this week more time to spend on the display.This will be beautiful Peter! Look forward to the finished display. Also it’s a safer way to move the ship.
I have yet to build a case for any of my ships.![]()
