I use water-repellent Pattex glue. To fold the strips, I built a template of the same curvature as the bow wheel, made up of two pieces between which I tighten the previously wet strip. Then I take it off when it's dry and place itThat looks great, nice progress. What do you use for glue?? I had a wee bit of trouble with planks 2, 3 and 4. The scarf joint separated when I bent the wet plank. I used Titebond II to glue those joints and the combination of wetting and heat was a problem.
Jan
I've switched to Titebond III for the scarf joints. It's waterproof. I heat bend the plank/strake , wet the area to be bent and apply heat starting at the the furthest wet point in and work my my way forward to the tip. Takes about five minutes or so to get the right bend.I use water-repellent Pattex glue. To fold the strips, I built a template of the same curvature as the bow wheel, made up of two pieces between which I tighten the previously wet strip. Then I take it off when it's dry and place it
Good morning Jan. Yep we do that with our kids. My daughter always tells me I’m technologically hindered and I just tell her I employ people to to that for me and just smile and nod….Wow, time flies. Its time once again to thank all of you who have taken time to stop by and check out my rambling, sometimes confusing and bumbling build log of this great Galleon. I'd love to type individual thanks but my Apple keyboard and I have a love/hate relationship (mostly hate). I spend more time backspacing to correct my bumbling fingers keystrokes than I do getting my message typed. (Hah, old dog new tricks??? Nope, that's not me). When he kids say, "Geez, POPS, you have to get current", I just smile, nod my head, and .....
Jan
Good morning. Your galleon looks awesome. I was wondering. Do you have a build log? It would be wonderful to see another modeler building this intriguing kit. Cheers Grant
Hi, no, I'm sorry, I took advantage of the log of Jan to publish some photos of my model under construction. I take this opportunity to apologize ti Jan if I invaded his wallGood morning. Your galleon looks awesome. I was wondering. Do you have a build log? It would be wonderful to see another modeler building this intriguing kit. Cheers Grant
Good morning. I’m sure Jan had no issues. Your build looks so cool it would be nice to see a build log. Sorry Jan for Hi jacking your logHi, no, I'm sorry, I took advantage of the log of Jan to publish some photos of my model under construction. I take this opportunity to apologize ti Jan if I invaded his wall
Hi Jan, if I may ask you something. I have to place the strip n. 5 but I saw that in the center there is still some space with respect to the upper one (n.6). How did you do it? Have you encountered the same problem?I managed to plank down to the keel. BUT plank #1 needs some serious work to finish closing in the hull. The space for that plank is a bit smaller than anticipated.
The circled area has been a wee bit of a problem. Several of the scarf joints separated when I was attaching the planks to the frames. The process of wetting and bending caused the PVA glue on the scarf joints to “ weaken”. I’ve been using Titebond II throughout the build but now need to find another type of glue for those joints.
No apologies necessary. I think it’s great that you are willing to share your work.Hi, no, I'm sorry, I took advantage of the log of Jan to publish some photos of my model under construction. I take this opportunity to apologize ti Jan if I invaded his wall
Excellent. That fit looks good. I’ll be interested in your fit of plank #1 (the garboard plank). I’ve not taken the time to fiddle with that one.
ThanksLooking very good - and it seems, that the planking elements are fitting well
