Nikitin San Bartolome 1584 A.D. (Kit #35)
OK MY 2 CENTS (INFLATION) THIS IS FOR THE MODELERS THAT ARE NOT SO SUPER LIKE ME, FOR REMOVING PLANKS OR OTHER PARTS THAT I AM AN EXPERT MANY TIMES OVER. WHAT I DO BOTH PVA AND CA IS USE NAIL POLISH REMOVER MUST BE REPEAT MUST BE 199% ACOTONE PUT IT ON JOINT CAREFULLY PRY IT LOOSE BE PATIENT MAYBE 2 OR 3 TIMES PUTTING IT ON JOINT WILL COME APART WITH NO DAMAGE TRY IT. AS FOR BENDING THAT AGAIN IS NOT MY FAVORIT TASK MANY, MANY REPEAT MANY MISTAKES MADE LOTS OF MONEY ON DIFFERENT BENDERS I THINK I HAVE FOUND ONE IT IS WHAT THE LUTHERS USE FOR GUITARS ETSN IT IS ELECTRIC YOU SET THE HEAT AT WHAT EVER IT NEEDS UP TO 350 D WET THE PLANK AND BEND IT TOO WORKS AMAZON $90.00, JUST FINISHED BENDING SOME VERY DELICAT CLAMPS FOR PAVELS SCHSLLOP VERY THIN AND DELICATE SET THE HEAT AT 150 D AND WET IT BEND NEXT ONE WAS ALMOST A DISASTER SOME HOW THE TEMPERATURE GOT SET AT 250 D OH, OH CAUGHT IT IN TIME IT TOOK LIKE 30 MIN TOCOOL DOWN TO RIGHT TEMPERTURE WILL BE USING IT TO BEND THE PLANKS AND HAVE TESTED IT WITH MUCH THICKER MATERIAL SET AT 300 D IT TOO WORKED MY 50 INFLATED OPION RESPONCE IF YOU CAN. GOD BLESS STAY SFE ALL DON
Don thanks for the info. I’ll have to look that tool up. So far the bending iron I got from Kolderstok has worked OK to bend the planks. I’ve learned to take my time and try not to force anything.
Jan
I WILL POST A PICTURE OF MINE, STEW MAC HAS ONE BUT IT IS TWICE THE PRICE THERE ARE SOME LIKE I HAVE ABOUT $60.00 UP TP $90.00 DO NOT REPEAT DO NOT GET THE CHEAP ONE MINE WORKS FINE SO FAR THE $90.00 ONE. SORRY I DO NOT HAVE A LINK BUT WILL TRY TO FIND IT. GOD BLESS STAY SAFE DON
@Philski,
That is quite the tool that Don is using. The specs are worry some, if I read them right the temperature settings are in Centigrade. After watching several of the videos of the tool in use and reading the reviews I think I prefer using my method.
So far this tool has worked great for me.
I’ve have two heating elements (30W,40W) I purchased from Walmart that I use with the Kolderstok tips. With patience I’ve been able to bend quite a few planks into their required shapes.
