Welcome to my bumbling, rambling effort. I'm having great time with this build.Checked out your build log. Looking great so far.
Good morning Jan. This is a good plan. Cheers GrantView attachment 367275
Dry fitting the gap filler on the left side and adjusting planks over the gunport openings. I think that this might be a good solution.
Jan
Hi Grant. Indeed this method is something I can do easily and hopefully not bugger up.Good morning Jan. This is a good plan. Cheers Grant
into the sunset Good morning Jan. That is a hectic stern. It’s looking ready to make pretty. I think you are going to have to be very patient and “gentle “ with your trimming and sanding. No Grant “hacking” here. I also think some custom designed sanding sticks and blocks will also do the trick. That was quite a task successfully pulled off. Cheers GrantOkie - Dokie. A couple of little mistakes here and there, but I think I have the general shape.
I now need to figure out how sand all of this planking to shape, lots of edges to “trim”.
Jan
Indeed, I’m going to be very,very, very careful with the trimming process. Watching Pavel’s video is a great help, but he does it in less than a minute.Good morning Jan. That is a hectic stern. It’s looking ready to make pretty. I think you are going to have to be very patient and “gentle “ with your trimming and sanding. No Grant “hacking” here. I also think some custom designed sanding sticks and blocks will also do the trick. That was quite a task successfully pulled off. Cheers Grant
Good morning Jan. Starting to look awesome. I still cannot get over the shape of her….One crazy ship. Cheers GrantIt took a lot longer than Pavel’s video. A combination of hand sanding, filing, Dremel grinding drum and holding my breath worked out to get this result. Probably it will need adjustments here and there when I plank the hull.
The real sawdust cloud begins in the morning when I start fairing the hull.
Jan
Hi Peter.Good afternoon Jan, i missed a couple of weeks, and had to catch up a bit, but your 3D jig-saw puzzle is starting to look great
Than you for stopping by and also for that piece of information. All the San Bartolome videos are a great source of assembly information.Good afternoon.I'm looking after your ship construction.a grandiose project.I decided to write to you for greater accuracy.the modeler who is assembling the video is called Oleg Ivanovich.
