Hello Stephan, I also thought about the laser, the problem is that the deck is curved
That problem also exist with the pencil.Hello Stephan, I also thought about the laser, the problem is that the deck is curved
Paul, thank you and you're not too late, it's coffee and cake right nowWell, I'm a bit late to the party...but I do wish you the happiest of birthdays. I hope you had a wonderful day celebrating with family and friends.
Hello Stephan, thank you, Ancre's plans and especially those of GD are really great.I wish I got such beautiful plans.. less thinking, more building.
I love the look of the wood and your accuracy.
Christian thank you too. I have to admit that both are very difficult, which is why everything that belongs to La Palme is cleared away when I'm working on Le Rochefort and vice versa, there's no other way.Hi Tobias,
really nice work. Your hawse pieces are turning out very well. I am allways fascinated that you can focus on two such big projects in the same time.
Dear Tobias,
great work, Your small fillers are fitting into the ship smoothly![]()
Shota also a thank you to you as well as to you Mirek.Witaj
Pięknie zrobione i opisane ,będzie pomocne dla kolegów budujących ten model. Pozdrawiam Mirek
In effetti, uno dei problemi dell'autocostruzione in arsenale (skills, spazio per l'atelier e attrezzatura a parte...) è la proprio la quantità e lo spessore delle tavole necessarie. Grande iniziativa, in ogni caso. Seguirò il lavoro con vivo interesse. Cordialità.Innanzi tutto Auguri Tobias.
Centomila complimenti per questo capolavoro. Mi sto preparando anch'io per la costruzione del Rocheforth. Nel senso che ho acquistato il libro la monografia e attrezzature varie. Una ventina di anni fa ho fatto la Prince della Amati dai disegni. Ora mi cimenterò sul Arsenale.
Volevo chiederti il legno (di pero),che misure e quantità dovrei comperare dal libro e monografia non trovo una lista o circa la quantità.
ti ringrazio se mi risponderai tu o chi volesse farlo.
Grazie e continua che sei molto professionale.
Roberto
Roberto
First of all congratulations Tobias.
One hundred thousand compliments for this masterpiece. I too am preparing for the construction of the Rocheforth. In the sense that I bought the book, the monograph and various equipment. About twenty years ago I made the Prince of Amati from drawings. Now I will try my hand at the Arsenale.
I wanted to ask you about the wood (pear), what sizes and quantities I should buy from the book and monograph, I can't find a list or about the quantity.
I thank you if you or anyone who wants to answer me.
Thank you and continue that you are very professional.
Robert
Hello Triestin and Albert,In effetti, uno dei problemi dell'autocostruzione in arsenale (skills, spazio per l'atelier e attrezzatura a parte...) è la proprio la quantità e lo spessore delle tavole necessarie. Grande iniziativa, in ogni caso. Seguirò il lavoro con vivo interesse. Cordialità.
Indeed, one of the problems of self-construction in the arsenal (skills, space for the atelier and separate equipment...) is precisely the quantity and thickness of the boards needed. Great initiative, in any case. I will follow the work with keen interest. Friendliness.
grazie della risposta. il posto dove fare i lavori lo ho. le attrezzature ho di tutto e di più (faccio modellismo dall'età di 11 anni con mio zio. adesso ne ho 55 solo che avevo dato via tutto e mi ero dato alla plastica adesso guardando vari post di facebook ,e vari forum mi è ripresa la voglia del legno in particolare modellismo d'arsenale. attualmente ho in lavoro la flying dutchman della occre. se mi appassionavo prima al arsenale i quasi 400€ li dedicavo alla costruzione d'arsenale.Ciao Triestin e Roberto,
Prima di tutto grazie per le tue gentili parole, molto apprezzate. Nella costruzione dell'arsenale, ovviamente, c'è più sforzo, soprattutto quando si tratta delle macchine e della loro acquisizione. Che tipo di legno viene utilizzato dipende sempre interamente da te, qualunque cosa ti piaccia, è una questione di gusti. Io uso pera, acero americano, castello ed ebano o carpino nero. Devi prendere le dimensioni di cui hai bisogno dal mono. A 1:36 il telaio ha uno spessore di 5,3 mm, avevo bisogno di 5 schede con 1000 mm x 100 mm x 5,5 mm per tutti i fotogrammi.
1 tavola di 1000mm x 100mm x 7mm per la chiglia.
Hi Jan, thanks for the congratulations.Wow, just catching up. What great build log.
Also very belated Happy Birthday.
Jan
