Thank you Mark.Great re-do Daniel, well done!
Yes, I looked at that while doing research , and I noticed it has a cherry stain with gloss finish. Definitely looks good!I am leaning towards the newer look such as the BN 2 has, with a clear poly finish. This will take some sample sections to try it on first.View attachment 380583
Good morning Daniel. I think “pleased is an understatement “. You are owning the deckI'm back on track with my deck redo and am pleased.
Now that couldn't be anything else but an utterly satisfying deck re-do!Good evening, all,
I'm back on track with my deck redo and am pleased. I still have a lot of sanding to do and some experimenting with some stains, but it feels good to have a method I can live with. Take a look.
View attachment 380577View attachment 380578
Till next time, thanks for watching.
Thanks Grant, I've always liked the notched frame boarder for decking on ships.Good morning Daniel. I think “pleased is an understatement “. You are owning the deck. Brilliant redo Daniel. I love the butt joints at the stern. Couldn’t have been easy. Cheers Grant
Thank you Johan, now if I can just get the finish I'm looking for.Now that couldn't be anything else but an utterly satisfying deck re-do!
Awesome job Daniel. I found the oak stain, on my cannon came out a little shinny as well. After a week or so this shinny effect reduced to almost zero. Perhaps your deck will have the same good fortune. My shinny issue is with my Matt ploy which is taking forever to dry. Weird. Cheers GrantI finished planking the cabin deck level. I chose a theme for exposed crossbeam viewing where the cabin itself would be completely surrounded by the decking then hand sanded it with 220 and 320 grit paper.
Next, I masked off critical areas prior to staining.
I hesitate to show the next slide because I hate staining, I can NEVER get it looking even all over! You can see some sampling I did with some amaretto stain which had too much red for my taste, so I went with Golden Oak.
And finally, after 3 coats of clear poly with a steel wool buffing in between each layer.
Depending how this shiny deck grows on me I may give it one more coat of matt finish poly, I have time to digest this for now. The addition of the deck fittings and being white may complement a shiny deck, we shall see.
Hope you enjoy.
Thanks MarkNice decking work Daniel, it came out very well![]()
Thanks Grant, I was actually shooting for a shiny deck with clear gloss poly. I wanted to see what it looked like. The stains and poly coatings I am using are water based and dry to the touch in less than 30 minutes and can be recoated in one hour. Are you using oil based finishes which do take a long time to dry even in low humidity weather??Awesome job Daniel. I found the oak stain, on my cannon came out a little shinny as well. After a week or so this shinny effect reduced to almost zero. Perhaps your deck will have the same good fortune. My shinny issue is with my Matt ploy which is taking forever to dry. Weird. Cheers Grant
