Dat is mij zeker gelukt Johan, bedanktTe laat, als mosterd na de maaltijd...
Ik hoop dat je op gepaste wijze je verjaardag hebt kunnen vieren, maar vooral dat je het komende jaar weer veel mooie herinneringen kunt maken.
Thanks Uwe, the quality is superb. I'm saving money at the moment for the diamond version. These are on my wishlist too.Looking very good - and with your new set of needle files it will get even faster in future.
I have this set also - very good quality
Thanks Shota, nice words you give me.Glad to hear that you had a pleasant birthday and that you received a gift that you liked / needle files. I admit that I salute your persistence and commitment to a no less excellent process and result, well done friend![]()
Thanks Paul, the first part of this shell first build is ready. Now it is a little more like most other builds, starting mouting frame timbers. Floor first.This is really looking great Stephan! I'm happy to see those partial frames in place as a guide - the contours look very much improved to this landlubbers eyes now.
Thanks MaartenVery clean work Stephan, looks great.
Thanks Tobias, yes I'm glad with the files and with the shape of the ship take out so well.Hello Stephan,
it's nice to hear that you were able to enjoy your birthday. Very nice set of files, I have them like Uwe and they are wonderful. The structure of your Hohenzollern is taking shape, really fantastic work.
Almost. Actually it starts after bilge and planking of the bilge. I skipped the planking of the bilge and start in this stage of the build. It is almost impossible to go further without these floor timbers. The scale is to little to get the shape of the HZ ship I try to duplicate. Something I have to deal with from the beginning.Is this now where you transition from "shell first" to "plank-on-frame" building?
is this due to the more compound curvature of the planks, or more that small deviations resulting in large mismatches between planks and frames, once you start installing the latter?It is almost impossible to go further without these floor timbers. The scale is to little to get the shape of the HZ ship I try to duplicate. Something I have to deal with from the beginning.
Both, because it is all small and a half mm. in the curvature will be a bigger mismatch in the top. Dificult to get these small planks in the right shape and place without these timbers in placeis this due to the more compound curvature of the planks, or more that small deviations resulting in large mismatches between planks and frames, once you start installing the latter?
I can only imagine that. To me the shell first method seems quite complex and prone to errors. I would say this is for experienced shipwrights/builders only.Dificult to get these small planks in the right shape and place without these timbers in place
No, no, I'm not experienced. It is fun. Just don't care to much on the shape, let there be a bit of tolerance in the build.I would say this is for experienced shipwrights/builders only.
Yeah, right...No, no, I'm not experienced.
You made a nice progress, Stephan. Nice tinkering with the floor timber parts of the frames. The reinforcement in the middle is a good option to absorb the forces of the curved hull planks.@ All thanks again for the visit, the comments and the likes.
I started to make the frames of the drawing I got from the book and made in AutoCAD. First the frame 9 and 11.
I made a design to cut out by hand. (the wood you see I cut from a table top of cherry on my Scheppach Basa 1 bandsaw)
Then I dry fit them together to look if it is roughly okay.
Then I glued the floor timber or crutch (I think crutch because the planking of the floor on that place is going vertical) together. And make a wooden connection between both parts for reinforcement.
View attachment 384691View attachment 384692
After that I drilled the holes in the parts that connect to each other and lay them on the plan to fit them in the right way. With pieces of scratch wood I fixed them. So I can take them apart.
The working space is started to look messy but cosy at one time.
After the parts are dried I make the crutch fit perfectly to the hull, and glue it in place after a few tiny corrections.
View attachment 384697View attachment 384698
This is how it looks when they are in place. Include the bilges on the main floor timber. (frame 17)
Then I start with the frames 21, 23 and 25. First on paper, then roughly cut out. The same way as I done before. After that is done I only have to make the floor timber number 14 and then I can go on with the planking.
Thanks for watching
Thanks Peter. Yes especially in the stern part of the hull there are some tensions in the hull.You made a nice progress, Stephan. Nice tinkering with the floor timber parts of the frames. The reinforcement in the middle is a good option to absorb the forces of the curved hull planks.
Regard, Peter
