Thanks Paul, I now have to go vertical starting with my old friends the dead eyes!Now I see how you completed your Vasa so efficiently! No moss growing on this build...
Thanks Dean, its onward and upward now.Beautiful execution Daniel. Those tie in very well with your color scheme.![]()
Thanks to your post on the dories, I checked my own posts regarding those darn/darling little things.Thank you, Johan, my hat is off to anyone who builds a Billling Boat product.
Johan I just had to laugh at your dory build (I was just going over it) when you said, "truly evil design." I didn't mention it, but I agree with you 100 percent.Thanks to your post on the dories, I checked my own posts regarding those darn/darling little things.
I realized I did use the parts supplied by BB, but those have become a bit unrecognizable because of the customizations.
I still kept one of the dories from the YQ-KIT, just to remind me of how difficult they were to build.
I’m living it!Thank you, Johan, my hat is off to anyone who builds a Billling Boat product.
Yes, Dean you are and doing extremely well with it.I’m living it!![]()
Thanks Daniel, you did a great job on your Vasa!Yes, Dean you are and doing extremely well with it.
One of the most beautiful ships ever built have these little bathtubs plonked on the deck.
I think the dories might have been rather esthetic when compared to the other stuff floating around on- and below decks: bait being put on the fishhooks, fish being hauled from the dories into the fishholds and fish being relieved from their entrails, the stench of fish everywhere...The dories. I never get these on the BN. One of the most beautiful ships ever built have these little bathtubs plonked on the deck.
Nice process you developed for your deadeye attachments.Since beginning this journey, I had built up in the back of my mind how difficult the dead eye install was going to be. Well, it turns out that this procedure is not as difficult as I had imagined. After fiddling around for an hour or so it dawned on me, I would need a jig of sorts to handle the small items securely while I assembled the parts. I got some ebony dead eyes from our friends at Dry Dock and went to work first with the jig which has three brass studs glued into a base board that I clamp down on my worktable. Then began stropping the dead eye for fit.
Next, I put a spot of CA on top, formed the loop on the end of the strap chain, placed a nail that came with the kit and squeezed it all tight for a few seconds to let the CA cure.
View attachment 390819View attachment 390820
After that I nipped the end of the nail, placed it all on my mini anvil, took a flat punch and smashed the end flat so it stays put.
View attachment 390821View attachment 390822
And finally placed as a dry fit and I believe this looks and works great.
Any comments or suggestions are always welcome.
Happy modeling!
Hi Johan, the large are 7mm, small 5mm.Nice process you developed for your deadeye attachments.
What diameter deadeyes are you using?
Aha, so you stuck to the original YQ dimensions, good.Hi Johan, the large are 7mm, small 5mm.
Hey Johan, did you drill your straps for nails on ship or off ship?Also those slots in the railings appear to line up correctly, great job.
I pre-drilled these holes off-ship. Unfortunately I painted the straps black before attaching them permanently, so I had a hard time locating the holes, once it came to final installation.Hey Johan, did you drill your straps for nails on ship or off ship?
Good afternoon Daniel. Wow this is good work. Cheers GrantSince beginning this journey, I had built up in the back of my mind how difficult the dead eye install was going to be. Well, it turns out that this procedure is not as difficult as I had imagined. After fiddling around for an hour or so it dawned on me, I would need a jig of sorts to handle the small items securely while I assembled the parts. I got some ebony dead eyes from our friends at Dry Dock and went to work first with the jig which has three brass studs glued into a base board that I clamp down on my worktable. Then began stropping the dead eye for fit.
Happy modeling!
Thank you, Heinrich, now if I can just attach the straps in a decent fashion and paint them all would be well. The sails however are beginning to loom heavy on my mind.Excellent work, as per usual, Daniel! I really like what you have done with the dories. Not only do they blend in beautifully with the color of your mother ship, but the grey interior adds a workmanlike (industrial-looking) effect to them which is perfectly in character with their function. The re-honed anchors look much sleeker and now I believe that whether you choose this configuration or fully stowed, both are viable alternatives. The deadeye assembly looks very good - personally I am so glad that the WB deadeyes are assembled with rope - those metal/wire straps on deadeyes look to be a real pain in the butt to assemble so neatly!
