The level of skill you bring to each task is simply overwhelming! Brilliant modelling Nigel! I wish I would have picked up this hobby when I was younger - all those years trying to master the game of golf...
Hey, golf was exercise. But now you can sand your arms into shape!The level of skill you bring to each task is simply overwhelming! Brilliant modelling Nigel! I wish I would have picked up this hobby when I was younger - all those years trying to master the game of golf....
Hi WillStep by Step you'll get there. The attention to detail is very entertaining. Rudder hinge soldering with the wood form how did you keep from burning? Was it resistance soldering used?
Hi UweVery good result - interesting way, to solder them all together in a row,
but you are showing, that this is the best way to get conformity
My dad DID manage to get me into golf and at my best I was pretty good. Not only did it facilitate some wonderful friendships, but the sport allowed me to travel the world as a player (not a professional - but there are all sorts of invitationals and tournaments for accomplished amateurs). I love links style golf in the UK and Ireland and have played all the major Open Championship venues along with about 50 other courses on that side of the pond. Injuries and age caught up with me. Now I drill tiny holes for tiny sticks of wood on tiny ships...and I've never been happier! Sorry for the diversion on your build report...Thankyou Paul, I would mention I have been doing this most of my life. Had you been doing this as long as I have, I can’t imagine the dizzy heights you would have reached by now.
My late Father was a keen golfer, he tried to get me into it but never got anywhere as it was not a cheap sport to get into as a kid. I had tennis coaching instead.
You guys building these beautiful Wooden ships amaze me with your wonderful talent, ive built balsa planes in the past, but the way you guys get the planking on these ships just as an example is amazing. I believe its done by soaking the blanks to make them pliable is that correct? Something i always wanted to build but iam hesitant incase i make a total mess of it.I used a pair of the kit scrolls to make a master. The one with the tip missing was built up with Mr Hobby putty. A silicon mould was taken from these enabling me to cast 8 new scrolls (4 pairs) out of Polyurethane casting resin. Apology for the picture, the camera did not want to focus very well.All the detail is there, just hard to see as they are white.
I have also epoxied the kit castings in place. I toned down the Ultramaine blue and it looks a lot better in reality than it does in the pictures, it is nowhere near as bright in reality. I may paint over the blue with the same wood varnish once the paint has been left for a few days, these should blend further as the varnish has a brown tint.This will also remove the shine from the exposed Epoxy glue
Kind Regards
Nigel
View attachment 389307View attachment 389308View attachment 389309View attachment 389310
Wow, I would say more than pretty good, much like your modelling Paul.My dad DID manage to get me into golf and at my best I was pretty good. Not only did it facilitate some wonderful friendships, but the sport allowed me to travel the world as a player (not a professional - but there are all sorts of invitationals and tournaments for accomplished amateurs). I love links style golf in the UK and Ireland and have played all the major Open Championship venues along with about 50 other courses on that side of the pond. Injuries and age caught up with me. Now I drill tiny holes for tiny sticks of wood on tiny ships...and I've never been happier! Sorry for the diversion on your build report...
Thank you so much for the information truly amazing model buildingHi Bren
Thankyou, the initial planking is bent with heat and water on this model.I soaked the planks then created the curves using a plank bending iron.More stubborn planks and tighter bends necessitates repeating both operations.
The final layers on this model are Veneer sheet, 0.7mm thick. These easily follow the curves without any soaking or heating but have had to be shaped from sheet to get the curves at the bow.
Thanks UweEverything fitts very good - very good work.
One question: will you keep the hinches black, or will you also whiten them in the area of the white stuff, means lower than the waterline?
Great work on the rudder Nigel. Really tight to the stern post and all different colours beautiful in line. A job well done.I completed all the rudder hardware and installed it on the rudder, everything relies solely on Dry dock models and parts tiny nails. These have no point so holes are drilled and they are carefully bonded in with medium CA.
The assembly was the carefully slid onto/into the model and all the remaining holes drilled and pins fitted.
The last two pictures show how tight the Tiller arm is in the transom hole and how close it comes to the underside of the deck beams.
My aim with this job was to get the rudder as tight as is possible to the stern post and also that the design has the capability to work which was not easy given how tight everything is with the cabin above.The Rudder does turn freely in both directions for the full arc
View attachment 390563View attachment 390564View attachment 390565View attachment 390566View attachment 390567
What Marc said...Splendid!
