    **VIEW RULES HERE**
Thanks, Johan.
About the lapjoints. As seen on the old drawing, they started with the sheet of the railing and then every lower sheets with the top over the bottom of the previous one:
But on the insert you can see that on the Balder this middle sheet has a overlap of the one above and below.
The Balder has been restored twice and some of the sheets have been replaced. Then I don't think they could have avoided deviating.
An advantage if I make a mistake later, I simply used a 'restoration pattern'.
And as I already indicated, no flanged edges on the Balder. But I did that to also try it out on this scale. Without them the transitions automatically become tighter.
It is conceivable that during the restaurations they opted for improving the corrosion protection by overlapping the sheets as shown in the RH picture. Conceivable, but that's all it is.
Another thing which struck me was the triangular shaped openings between the lap-joined sheets and the skin flange of the frames; an open invitation for corrosion to start it's disastrous work. The good thing is it won't effect your build.
Already looking forward to the AL-FI declarations... ;)
Yep Green most definitely…and Peter must have many :D
Nope, it’s my Admiral’s ScrapBook cutting mat, but I used it at most. I prefer a mat in see-green/see-blue, depending on what kind of light source is illuminated. I prefer the old natrium, because then you really don't know what the original color of the subject is. Any discussion about the correct color can be ended immediately.
So my mat is purple-pink-orange with a hint of indefinable brown ………
I find your thought process enlightening to say the least, Peter. This is why you turn out models like the Robert E. Lee, the Pocher Ducati and the Bluenose. The phrase "attention to detail" doesn't cut it when it comes to your work. I am not commenting much, because I have absolutely zero experience of the materials you are working with, but I am watching very carefully.
Thanks, Heinrich. You can process Evergeen in almost the same way as wood. Bending with heat, drill, file, sand, screw etc. You only need another type of glue.
They have a huge variety to profiles, sheets etc:
I used it already for some parts on the Lee and the Bluenose and already have a nice collection:
I only need a few more that correspond in size and profile to the dimensions of the old drawing, related to 1:50.
But Raboesch has also a great variety.
Hi Peter,
Have you already informed Evergreen so they can increase the production? ROTF
For those interested a little preview: in Fushion 360, drawn in the Y-line drawing (width), projected at the bow in the X-line (length) drawing, the first 5 Station Lines started from the bow. And transferred in the X-line drawing (length) in the length from the bow till midship:
When you know how to do ……. Then it is …… But before you know ……. RTFM
And the used lineplan:
(Source: Drawing from the SZB)
Now I have to flip the Y-line drawing to draw the 7 line till the stern.
Ciao Peter.
Il tuo nuovo lavoro è interessantissimo.
Hai iniziato nel migliore dei modi. La lunga descrizione storica è molto gradita per me. Apprezzo molto gli approfondimenti di questo genere con foto e informazioni.
L'uso di un programma di disegno 3d (nel tuo caso Fushion360) lo renderà ancora più interessante ai miei occhi.
Spero che inserirai molte foto e spiegazioni al riguardo.
Hello Peter.
Your new job is very interesting.
You're off to a great start.
The long historical description is very welcome to me. I really appreciate insights like this with photos and information.
The use of a 3D drawing program (in your case Fushion360) will make it even more interesting in my eyes.
I hope you will post lots of photos and explanations about it.
Ciao Peter.
Hello Peter.
Hi Alessandro.
I'm glad you appreciate my introduction.
Learning to work with a 3D CAD program takes a lot of time. As soon as there are more results, I will certainly post them. My hopes are partly based on a friend of mine who is entering the old line plan into AutopCAD. He works every day with AutoCAD at a shipyard where luxury yachts are developed and built.
So, hopefully soon more to post ……
Hi Alessandro.
Aspetterò con interesse e curiosità.
I will wait with interest and curiosity.
It was quiet on the yard for a while, but that's because I've made a start on the actual shipyard:
The keel is placed on the main beam with the cross beams. The base plate is inclined by 1.5 degrees, because on the old drawings the keel beam also slopes forward by 1.5 degrees.
Placed the bow section and laid the first part of the keel:
These parts are made of 0.5 mm thick sheet material and strips.
What's the point of those two cleats around the main beam?
I sawed my Bluenose in half at the waterline because I wanted to build the interior and have it be visible.
This image also appeared in my Bluenose report:
The half-open lengthwise model.
In Paul's @dockattner report of the Kingfisher this model was mentioned:
So many things were going through my mind before starting to build my new model. I had already mentioned that I also wanted to build the entire original construction and interior of the Balder. That must be visible.
To avoid having to put the saw back in, it is best to take this into account in advance.
If you look closely, you will see the bow and keel parts consist of 2 lengthwise parts:
The bow and keel plates are temporarily connected.
If I remove both clamps, I can separate the 2 floor parts on my base plate:
And the bow and keel parts got separated.
With a look from the front:
At the beginning of the left floor section you will see a small block. That's at the back too. Both floor parts slide over it so that I can always fix those parts against each other in the same position. Clamps on and I can continue building.
Now I first have to install the 2 test frames as a test to see whether what I have devised is actually workable.
My intention is to completely furnish and clad the starboard side. The port side remains open so that the construction remains visible.
In the meantime, we continue to draw...
This is a great look on a future build. A big WOW if you could achieve this. Because this is not a easy job and if somebody could do this, I think it's you.
Thanks, Stephan. I have to think a lot of steps ahead.:rolleyes: Also by building the frames I have to have in mind that they must be separated, included to molds that will keep them in place.
Once I have taken both floorboards apart, I can tilt them a quarter turn so that the vertical inner side rests on the worktop. And I can build and align both halves neatly flat so that once they are upright again, they also connect neatly in the lengthwise direction. But of course I will clarify that with photos.Explosion
Regard, Peter
WOW, you are off to a very good start, Peter,
Thanks, Jim. When the start and the base are solid, then the rest ……… ;)
Well, just what I answered Stephan, now it’s thinking a lot of steps ahead.
And I will probably have to make some adjustments, but that generally went well with the Bluenose. :)
Regard, Peter
Hi Peter,
That is some undertaking indeed.
Are you going to place some kitchen cling wrap between the parts you don't want to glue together?
Cheers,
Stephen.
Hi Stephen.
I don't oversee everything yet, but everything starts with an idea and a start to implementation.
About wrapping: hopefully not and it will remain just gluing and imitation riveting.
Hi Stephan.
Hi Peter,
The cling wrap idea was more for preventing accidental gluing of the 2 keel sides together, quite easy to do with thin wick in adhesive.
Cheers,
Stephen.
