WYSIWYGHe got a green mat, for sure. See post #3
It is conceivable that during the restaurations they opted for improving the corrosion protection by overlapping the sheets as shown in the RH picture. Conceivable, but that's all it is.Thanks, Johan.
About the lapjoints. As seen on the old drawing, they started with the sheet of the railing and then every lower sheets with the top over the bottom of the previous one:
But on the insert you can see that on the Balder this middle sheet has a overlap of the one above and below.
The Balder has been restored twice and some of the sheets have been replaced. Then I don't think they could have avoided deviating.
An advantage if I make a mistake later, I simply used a 'restoration pattern'.
And as I already indicated, no flanged edges on the Balder. But I did that to also try it out on this scale. Without them the transitions automatically become tighter.
Yep Green most definitely…and Peter must have manyI think that you are really on a very good waylooking very promising
BTW: Which colour does your cutting mat has? I guess green based on the actual thesis by @Steef66![]()
Nope, it’s my Admiral’s ScrapBook cutting mat, but I used it at most. I prefer a mat in see-green/see-blue, depending on what kind of light source is illuminated. I prefer the old natrium, because then you really don't know what the original color of the subject is. Any discussion about the correct color can be ended immediately.Yep Green most definitely…and Peter must have many![]()
Thanks, Heinrich. You can process Evergeen in almost the same way as wood. Bending with heat, drill, file, sand, screw etc. You only need another type of glue.I find your thought process enlightening to say the least, Peter. This is why you turn out models like the Robert E. Lee, the Pocher Ducati and the Bluenose. The phrase "attention to detail" doesn't cut it when it comes to your work. I am not commenting much, because I have absolutely zero experience of the materials you are working with, but I am watching very carefully.
evergreenscalemodels.com
Hi Peter,Thanks, Heinrich. You can process Evergeen in almost the same way as wood. Bending with heat, drill, file, sand, screw etc. You only need another type of glue.
They have a huge variety to profiles, sheets etc:
I used it already for some parts on the Lee and the Bluenose and already have a nice collection:![]()
EVERGREEN SCALE MODELS
EVERGREEN SCALE MODELS IS THE FOREMOST PRODUCER OF POLYSTYRENE STRIPS AND SHAPES FOR MODEL MAKERS ARCHITECTS, AND ARTISANS AS WELL AS THE OEM MARKET.evergreenscalemodels.com
I only need a few more that correspond in size and profile to the dimensions of the old drawing, related to 1:50.
But Raboesch has also a great variety.
You won't believe it, but they offered me shares for a fair price ……..Hi Peter,
Have you already informed Evergreen so they can increase the production?![]()
Ciao Peter.For those interested a little preview: in Fushion 360, drawn in the Y-line drawing (width), projected at the bow in the X-line (length) drawing, the first 5 Station Lines started from the bow. And transferred in the X-line drawing (length) in the length from the bow till midship:
When you know how to do ……. Then it is …… But before you know ……. RTFM
And the used lineplan:
(Source: Drawing from the SZB)
Now I have to flip the Y-line drawing to draw the 7 line till the stern.
Hi Alessandro.Ciao Peter.
Il tuo nuovo lavoro è interessantissimo.
Hai iniziato nel migliore dei modi. La lunga descrizione storica è molto gradita per me. Apprezzo molto gli approfondimenti di questo genere con foto e informazioni.
L'uso di un programma di disegno 3d (nel tuo caso Fushion360) lo renderà ancora più interessante ai miei occhi.
Spero che inserirai molte foto e spiegazioni al riguardo.
Hello Peter.
Your new job is very interesting.
You're off to a great start.
The long historical description is very welcome to me. I really appreciate insights like this with photos and information.
The use of a 3D drawing program (in your case Fushion360) will make it even more interesting in my eyes.
I hope you will post lots of photos and explanations about it.
Aspetterò con interesse e curiosità.Hi Alessandro.
I'm glad you appreciate my introduction.
Learning to work with a 3D CAD program takes a lot of time. As soon as there are more results, I will certainly post them. My hopes are partly based on a friend of mine who is entering the old line plan into AutopCAD. He works every day with AutoCAD at a shipyard where luxury yachts are developed and built.
So, hopefully soon more to post ……
This is a great look on a future build. A big WOW if you could achieve this. Because this is not a easy job and if somebody could do this, I think it's you.View attachment 398683
So many things were going through my mind before starting
Thanks, Stephan. I have to think a lot of steps ahead.This is a great look on a future build. A big WOW if you could achieve this. Because this is not a easy job and if somebody could do this, I think it's you.
Thanks, Jim. When the start and the base are solid, then the rest ………WOW, you are off to a very good start, Peter,
Hi Stephen.Hi Peter,
That is some undertaking indeed.
Are you going to place some kitchen cling wrap between the parts you don't want to glue together?
Cheers,
Stephen.
Hi Peter,Hi Stephan.
I don't oversee everything yet, but everything starts with an idea and a start to implementation.
About wrapping: hopefully not and it will remain just gluing and imitation riveting.
