Understand; those darn kit plans.... a bit work to do
Thank you for pointing it up..
Good morning. Excellent. Those rigging bits are perfect. Cheers GrantWork continues making two rigging bitts.
First I cut the lumber a bit longer that it is needed, approximately 30mm (20mm needed) so I would have a bit more handling space while working on a bench saw.. end that will be tapped is first sanded to 90 degree..
Then the 60 degree angle was applied on all four sides...
Making it to look like this:
Then I run all vertical posts thru bench saw to make small decorative cuts on all four sides and to make a slot for dado joint connecting elm back with bitt pins....
Slots are cleaned with scalpel and a file.. parts are glued and I added a nail in each connection point and at the bottom of the bitt pins. Bottom pin will assist holding it on the deck. 6mm wire simulated the nails which are then sanded flush.
After measuring, it was added to the deck.
Happy modelling..
Thanks Grant, appreciated.Good morning. Excellent. Those rigging bits are perfect. Cheers Grant
Thanks RDN1954, appreciated.Beautiful modeling!
Looking very good indeed. Cheers.Continue working on stays... foremast first... first had a simple seizing slide up to the stay rope and then run rope around the bowsprit two times...
Then the seizing was slide down and tighten, secured with a drop of CA. One side of the seizing rope was twisted around stay 6 times and again secured with a drop of CA. Excess seizing rope and stay rope was cut with scissors.
On shorter side of stay, I added another seizing loop and secured with a drop of CA.
Next were stays for mizzen mast. I was not happy with one I made before, after testing with lanyard, I noticed stay block will be positioned too low and will not be that visible. I removed blocks from stay but that, did not leave me with enough rope fix the block again, so decided to remove existing...
The new stays are done with two ropes, seized together. One side can be completely done and secured with CA, but the other side need to be left loose so it can slide over the mast.
The work was done with assistance from 4 hands...
Again, simple seizing rope was added, tight and secured with small drop of CA. One end of seizing rope was twisted around the stay rope and secured with CA. Excess was cut..
It was then attached to the mast..
.. and seizing loop was push towards the mast and secured with CA; few runs around the stay rope and another CA drop.
Excess stay rope was also cut.
Now I have enough rope to complete the work..
Happy modelling.
Good afternoon. Lovely work. Cheers GrantContinue working on stays... foremast first... first had a simple seizing slide up to the stay rope and then run rope around the bowsprit two times...
Happy modelling.
Hi Grant, thanks... appreciatedGood afternoon. Lovely work. Cheers Grant
Cheers, thanks ConsNZ, appreciated.Looking very good indeed. Cheers.
