I'll have to look into that. lolHi John,
The proverb is a man has to expand his limitations.![]()
And that will work for cleaning the deck as well, Zoltan?Hello John ,as I mentioned earlier just use a scraper ,the deck will look much better.
0.5 mm's. I just used a razor blade and it worked perfectly! And it even cleaned it up well, Zoltan. Thanks for the help!!!Give it a try ,how thick the planks are?
It worked out great, Zoltan! When I get back today I'll rub on the matte varnishJust don’t scrape it too much at 0.5 mm,,you could scrape away the planks,I used 1 mm thick
Hi John
Re deck, you can also use glass.
I cut some picture glass up into different sizes.
Denis.
Hi John,
Looks great, is there a lot of details provided in the kit for the gun carriages? You can add details by adding smal pins through the wheel shafts, add eye bolts and rings. add clamps for securing the gunbarrel etc. A lot of work however for the amount of gun carriages you have for this model but these kind of details will enrich your model greatly.
Looks good! Gonna try razorblade onze my deck from the wilhelm.
I only can only agree with you Brian,very nice and well designed kit and John is doing a fabulous job on her.This is a most impressive looking model. Well done so far.
