     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
PS A drawing error is also possible: we once found a 10 mm deviation for a wing attachment point in the master tooling. Luckily everything else was derived from said master tooling. We only discovered this discrepancy when we modeled the entire geometry in 3D and compared it with the master tooling models.You're absolutely right taking the line plan as your starting point, no questions asked.
With respect to the observed difference of 50mm; it appears that the 1550mm dimension is taken from the intersection of WL6 and (imaginery) frame 55, or your origin, to frame datum 51. The 1500 dimension seems to be taken from the intersection of the inner profile of the bow and the floor of the focsle to frame station 51. Unfortunately the construction drawing is not very clear, but it may be a plausible explanation.
Thanks for diving with me into de details of the drawings, Johan.You're absolutely right taking the line plan as your starting point, no questions asked.
Always: check, check, double check ……..PS A drawing error is also possible: we once found a 10 mm deviation for a wing attachment point in the master tooling. Luckily everything else was derived from said master tooling. We only discovered this discrepancy when we modeled the entire geometry in 3D and compared it with the master tooling models.
Quando i risultati superano le aspettative la soddisfazione è maggiore.Thanks, Alessandro. I am also happy with the result. Hoped in advance, but certainly not expected.
I again looked at the details you provided and I think the pitches are 390/390/390/330(=1500) and not 380/390/390/330(=1490).Thanks for diving with me into de details of the drawings, Johan.
The distance between those 4 is also different: 4x387.5 and 380/390/390/330.
This is not only the case here, but also with other frames. The differences are not large, but 'several times a little bit' gives undesirable differences. Especially because I have aligned everything with the sheer and curve on the outside of the deck via the lines plan.
Hi Johan. You are correct about the "380". The accent line went through the digits and its 390. Then the outcome is 1500.I again looked at the details you provided and I think the pitches are 390/390/390/330(=1500) and not 380/390/390/330(=1490).
That 2,5mm difference is a bit strange (the outlayer 330 not taken into account), which I can't really explain.
When you state that you observe similar deviations on other frames, you might be onto something; one error is possible, a second, similar error becomes a bit suspicious, but a third and consecutive deviations are no errors any more, that's deliberate. It might be a good idea to look for a rationale behind the deviations you find. Or stick to your plan and declare your basic surface and plane definitions being the "Bible".
I love the painting bulkhead. I would paint the shades (is it possible in general???) on revet head to outline them. Also, I am thinking of possibilities to make the frame already cut in half, and glue both sides lightly in a few spots. Then it should be easier to remove. Or I could be just wrong.'m not cutting the bulkhead in half yet. I'm going to make the frames 52, 53 and 54 first. If I can align it neatly and make it fit with an intermediate floor, then I will decide on the go or no-go.
Thanks, Uwe. I am also happy with the results.I love this result
You also thanks, Paul. It is the start that I can build on. With the next frame I hope to show something that can be recognized as the bow.Very nice Peter. The whole thing looks very promising and convincing.
Thanks for thinking along with me, Jim.I love the painting bulkhead. I would paint the shades (is it possible in general???) on revet head to outline them. Also, I am thinking of possibilities to make the frame already cut in half, and glue both sides lightly in a few spots. Then it should be easier to remove. Or I could be just wrong.
You also thank for thinking with me, Stephan. But sliding in the even-starboard frames into the uneven-portside frames will give a problem with the deck rounding. Or I must cut the curved top of the frames.Accurate as always. Love the tiny details and painting. Some extra rust or weathering to make it alive?
If I may make a suggestionabout the plans you have, don't cut the frames in half. But glue, I understood there are a lot of these frames, the even numbered frames to the starboard side. And glue the uneven numbered ones on the port side. That way you still maintain a stable situation When opening the hull. Just an idea I got when I saw your frame and that sawing through, as you indicated, does little good.
Good morning Peter. Wow! Just wow. This is going to be legendary. Cheers GrantWatertight bulkhead 51 is ready:
Lots of decal rivets that are now very dominantly visible. But just wait.........
The port side of the hull will be completely furnished, including hull plates.
The starboard side is pre-drilled for the rivets:
See the arrow at the side of the L-profile.
Then I looked for suitable paint.
Did an air-brush test with Vallejo Model Color, but it is too thick. Then the rivets are almost invisible.
It turned out, partly on the advice of Henk @Henk Liebre , that I should have a thinner Air:
The frontside. Now they remain subtly visible. The widest part is 72 mm, the height 78 mm.
The backside. With the insert detail picture with the pre-drilled holes.
I'm not cutting the bulkhead in half yet. I'm going to make the frames 52, 53 and 54 first. If I can align it neatly and make it fit with an intermediate floor, then I will decide on the go or no-go.
I realize more and more that it is becoming complex in terms of construction.
I still have to look at some details for those 3 frames, because I cannot get everything from the old drawings.
The keelson lies on the 'retaining frames' that partly merge with the regular frames. It is not yet clear to me which side they are both facing. Which parts of the two L's come together. Will it be a right-angled Z or a U? Later I will also clarify this part with pictures.
I also need to take a closer look at the connection with the deck beam and knee piece.
Next week a visit to the Balder. Actually today with the storm it was not responsible to leave on the motorcycle.
Stai ottenendo dei risultati eccezionali. Dei pezzi perfetti.Watertight bulkhead 51 is ready:
