What I respect most about you, Peter, is your ingenuity. Where I am more like a musician trying to read and play music created by someone else - you are a composer who is creating de novo. Marvelous stuff...
As an amateur musician I appreciate this wonderful compliment. Thanks, Paul.
After some minor adjustments, I placed the stringer from the bow/keel frame, over frames 53 and 51 and let the stringer rest on frame 39:
Here is the template with the position of the frames.
With the stringer in place. The stringer plate still needs to be riveted to the deck beam of frame 53 ……. ;)
The sheer is already quite evident:
It immediately gives the whole structure solidity.
Now I could also check the alignment over the 2 frames towards the bow:
In 4 positions with a strip of paper. This connected neatly to the sides of the frames. Particularly in frame 53, I bent the rear-facing side slightly outwards with a gradient from top (more) to bottom (less).
Gr. Peter
Gr. Peter
Magnificent work Peter. Thumbsup
Cheers,
Stephen.
Gr. Peter
Good morning Peter. Whew. That looks very delicate. Is there a reason why you did not (besides giving the structure some strength)
"lay" the frames 50 to 40 prior to the stringer? Cheers Grant
Good morning, Grant. My intention is to build the compartments from watertight bulkhead to watertight bulkhead. I first compleet the frames between the bow and 51. Also as a test if I can align them all in a correct way. Then the frames between 51 and 39, 39 till 14 and 14 to stern.
The stringer is one of my guild lines and I will increase every compartment and extend it to the next to prevent sagging.
Besides the keel is the double L-profile midship the 3th guide. But there are a few hatches and structures that disrupt that.
Is there a reason why you did not "lay" the frames 50 to 40 prior to the stringer?
Yes, I have not build them ……… ;)
o_O This looks probably more fragile than it actually is, but one thing's certain: you're one brave modeller.
Thanks, Johan.
I've already had some sweat on my forehead. :rolleyes:
When I see this picture of the restoration, the fragility is approximately 1 to 1 the same as that of the original Balder:
(Source: restoration book pag. 30 of the SZB)
The frames also look fragile. I think you can (als bend them with some force if there are no hull plates on it yet.
My build is also nice in comparison in that area .......... ;):)
The entire construction will provide stiffness.
Thanks, Johan.
Yeah, I went through the pictures and drawings you posted earlier, looking for some rigidity, before it all comes together. Surprise: there isn't much, other than the keel, the deck beam and the bulkheads. I was looking for alternative ways of assembling the hull; there are options, but those require more jigs to form and control the skins and frames. In short, it most definitely would not simplify your build.
The 4 front frames in place:
The floor of the forepeak was also custom made. Only the rivets were applied to the other side. Because they are in plain sight.
The alignment seems pretty good:
Now come up with something for the cement with which the lower part is filled.
I'll visit the florist for 'oasis'. Is easy to cut and who knows, with a 'concrete colour'.
Love your work
