What I respect most about you, Peter, is your ingenuity. Where I am more like a musician trying to read and play music created by someone else - you are a composer who is creating de novo. Marvelous stuff...
As an amateur musician I appreciate this wonderful compliment. Thanks, Paul.What I respect most about you, Peter, is your ingenuity. Where I am more like a musician trying to read and play music created by someone else - you are a composer who is creating de novo. Marvelous stuff...
Magnificent work Peter.After some minor adjustments, I placed the stringer from the bow/keel frame, over frames 53 and 51 and let the stringer rest on frame 39:
Here is the template with the position of the frames.
With the stringer in place. The stringer plate still needs to be riveted to the deck beam of frame 53 …….
The sheer is already quite evident:
It immediately gives the whole structure solidity.
Now I could also check the alignment over the 2 frames towards the bow:
In 4 positions with a strip of paper. This connected neatly to the sides of the frames. Particularly in frame 53, I bent the rear-facing side slightly outwards with a gradient from top (more) to bottom (less).
Gr. Peter
Thanks for this compliment, Stephen. The tests continue to go well so far.Magnificent work Peter.
Cheers,
Stephen.
Good morning Peter. Whew. That looks very delicate. Is there a reason why you did not (besides giving the structure some strength)After some minor adjustments, I placed the stringer from the bow/keel frame, over frames 53 and 51 and let the stringer rest on frame 39:
Gr. Peter
Good morning, Grant. My intention is to build the compartments from watertight bulkhead to watertight bulkhead. I first compleet the frames between the bow and 51. Also as a test if I can align them all in a correct way. Then the frames between 51 and 39, 39 till 14 and 14 to stern.Good morning Peter. Whew. That looks very delicate. Is there a reason why you did not (besides giving the structure some strength)
"lay" the frames 50 to 40 prior to the stringer? Cheers Grant
Yes, I have not build them ………Is there a reason why you did not "lay" the frames 50 to 40 prior to the stringer?
Thanks, Johan.This looks probably more fragile than it actually is, but one thing's certain: you're one brave modeller.
I've already had some sweat on my forehead.you're one brave modeller.
Yeah, I went through the pictures and drawings you posted earlier, looking for some rigidity, before it all comes together. Surprise: there isn't much, other than the keel, the deck beam and the bulkheads. I was looking for alternative ways of assembling the hull; there are options, but those require more jigs to form and control the skins and frames. In short, it most definitely would not simplify your build.Thanks, Johan.
When I see this picture of the restoration, the fragility is approximately 1 to 1 the same as that of the original Balder:
The frames also look fragile. I think you can (als bend them with some force if there are no hull plates on it yet.
My build is also nice in comparison in that area ..........
The entire construction will provide stiffness.
THANKS!COOL!
Got a tip on the Dutch forum: gray floral foam. Found it at a big ‘chain-store: 23x11x7,5 cm for: €0,55. Big investment, but I give it a try.I'll visit the florist for 'oasis'. Is easy to cut and who knows, with a 'concrete colour'.
Love your workThe 4 front frames in place:
The floor of the forepeak was also custom made. Only the rivets were applied to the other side. Because they are in plain sight.
The alignment seems pretty good:
Now come up with something for the cement with which the lower part is filled.
Thanks, Johan.Too soon to draw conclusions, but this certainly looks promising (asides from rather impressive...)
Thanks, Shota. It was a lot of learning in Fushion, but now the first results are there.Dear Peter.
you have done wonderful work with Fusion and the beginning looks promising![]()
Thanks, Grant. I also felt a smile come on after placing the 4th frame and the little floor.Love your work
