Slow progress but steady,
Yes you are correct......I try every day to work on her, but only in the night, possible for one or two hoursSlow progress but steady,
Some small progress for stiffening the hull. Time consuming work ..... the thickness of every piece had to be adjusted - one side permanently glued
View attachment 45157 View attachment 45158
View attachment 45159 View attachment 45161
UweK
You mentioned you'd be interested in seeing the mortar didit was having made when it was ready. I only had a chance to open the package and look at it tonight but here it is.
Uwe,
Will the sanding of hull be by hand or do have a “tool” for that?
I used a combination of hand sanding and a dremel with 25mm disks. I have been careful with the dremel. Using 120 grit disks at lower speeds. Only worked about 20 minutes a day. Worked slowly a little bit at a time with no hurry.During the last two evening I tried carefully different ways and tools, but at the end i have to recognize, that the hand sanding is the way, to get the best quality results. With every power-tool there is the possibility of un-wanted scratches and small damages. Outside the hull it is easier, Hull inside is much more complicate, and Hereford i am still learning, what is the best way......
Hi Uwe,
You can show is pictures of the piles of dust you have been creating.![]()
A very good pointAbsolutely stunning kit and workmanship! Your workshop leaves me a little envious as well! I was wondering about the use of various grades of steel wool
for final smoothing other than sand papers. I use steel wool for fine furniture refinishing as the wool tends to shave/slice off wood instead of disturbing the fibers with paper.
