I hope you will include some of your CAD drawings with the plans. The one posted here explains a lot.
PM me and tell me what you want, scales 1/64 1/48/1/40..I am very interested in a set of plans!
1:40 please, and postage to the UK.PM me and tell me what you want, scales 1/64 1/48/1/40..
I just noticed that the foot of the bow is squared off. I thought it was rounded to match the upward curve of the hull. Never noticed that before. I also have been reading my book on clipperships and it refers to frame dimensions as "side and moulded". Which is which for the frames?The kit will come with renders of the cad model at various stages, let me puta few up here now. rabbet tool, you should never cut the rabbet along the keel with strokes with the grain, it is nearly impossible to keep the chisel going at the right angle as the wood will have its own agenda.
this is why when real ships are built and the rabbet is adzed to form its done in vertical strikes.
Nope Cutty Sark had a square forefoot and always did, If it was rounded a tiny bit(there is evidence of it) but it was only about 6" to 12" radius at most it was removed very early on when replacing the stem.I just noticed that the foot of the bow is squared off. I thought it was rounded to match the upward curve of the hull. Never noticed that before. I also have been reading my book on clipperships and it refers to frame dimensions as "side and moulded". Which is which for the frames?
Why is that Dale?My brain hurts after this thread. Can I use some of those paper towels you have?
I have said several times that this is not a kit for a beginner and most model builders I know of have an MF70 Mill and Dremel., it's just an observation from watching other posts on sites like this, in fact wile watching other builds it was that that made me go and buy an MF70 mill, I only suggest it because the rails need to be grooved with a .5mm cutter to receive the topgallant rail and bulwarks, it would be difficult indeed to do it any other way.Couldn't a good model maker get the hull, frames and decks and do a decent job of the rest?
As for my brain, it is because what you are trying to achieve is fantastic and the knowledge you have is overwhelming. As for the paper towels, I just saw them neatly mounted under one of the shelves and thought "very organized".Why is that Dale?
