Tony!Hi
Time to forget the 3D Printer for a while and catch up with my progress.
This is the first time I've painted a model, I experimented with some different paints and decided to use acrylic. This is how I marked the level of the copper plates.
Three coats of each colour worked well.
The 8 sheaths where quite time consuming but they came out OK.
While painting I did some work on the gallery. This is a bit of a dilemma for me as I like the way they look but they're not correct to the ship. I've tried to alter the spacing so the bottom of the middle window is wider than the others, I couldn't make this work. This is due to the angle of the stern being to steep. A fix would be to shorten the width at the top of the windows but this makes the angle at the front of the gallery a lot sharper. I haven't decided yet but I leaning towards sticking with what I have.
And one with a window fitted.
That my progress up to date time to look into copper plating.
Tony
Hi MarcDear Tony,
I have a question for you!
I'm still working on the rigging of the guns.
I installed the breech lines and one gun tackle (each gun has 2 of them).
As you can see in the photo I would actually add a 3rd and 4th to wire the open eyebolts. But, is this recommended as I fear I will have an abundance of wires per gun....
What would / are you going to do?
PS
very nicely painted... perfect... and also very clever that you have now installed the sheaves in the hull before finishing further details... I followed the plans and only plan 4 are the sheaves discussed... .better at your stage!
Tony, nothing wrong!Hi Marc
Before I answer your question have a look at my last model and tell me what's wrong with the cannons?
Tony
I personally like the look. Well done.Hi Marc
Tony
I like your solution to an otherwise crowded and cluttered deck space. Nice job.Hi Marc
Tony
Hi Marc your right. Try without the blocks or use smaller ones but use the method your happiest with.Tony, nothing wrong!
The only thing I see is that you did not use SB & D blocks..... Doing so you have a very clean solution but nevertheless rigged the guns...clever.
So if I understand your suggestion right, continue without the blocks: fine for me... Is this right?
OK But I will follow your idea and finish the rigging without blocks....Hi Marc your right. Try without the blocks or use smaller ones but use the method your happiest with.
There's photos of the cannons fully rigged and partly rigged so you could leave one set off for a cleaner look.
One of the biggest problems with rigging the cannons is the blocks and fittings need to be very small. Both hard to find and time consuming.
While making my Unicorn I had a lot of trouble getting the guns to look right. I used the smallest blocks I could find but with the eyebolts hooks and blocks there wasn't much rope showing. I saw this method on another log and until I read about it and went back to look at the photos hadn't noticed there were no blocks. On my Unicorn log only one person commented on the way I rigged the cannons.
With my Constitution I will try a few methods and see what looks best once the cannons are made up.
Tony
Possibly saw the slots. Cut a base plate the size of the bottom of the foot and glue in place. No drilling, only sawing. I attached a crude drawing of what I tried to explain.A very fun (annoying) one is making the fife rails. More specifically, the sheaves in the bottom blocks: in a 5/32" block, 3 sheaves should be provided. Give it a try. I tried everything: drilling and grinding holes, milling, etc. until I finally simply tried with my cutter to carve three parallel notches and some from deep... the front one alone took me two full days... starting over and over again...; Now I don't know if anyone has a better idea because I still have to make the middle and back making...
Dear Jeff,Possibly saw the slots. Cut a base plate the size of the bottom of the foot and glue in place. No drilling, only sawing. I attached a crude drawing of what I tried to explain.
