- Jun 2, 2020
Tried that and it does not hold up :=(You could just cover the gap with a strip of tape.
That’s a very nice option for treenails, Uwe. Thanks for posting!Working on my HMS Granado treenails I recently found the (for me) best quality toothpicks
View attachment 423357 View attachment 423355 View attachment 423356
Yesterday I got some more, so my stock is full for the next two ship models - per box I have 1.000 picks - means 2.000 treenails - so with these 6 boxes enough for around 12.000 treenails ...... btw: it is not bamboo, but "real" wood - birch wood
or almost enough for one Kingfisher......Working on my HMS Granado treenails I recently found the (for me) best quality toothpicks
Half of a Kingfisheror almost enough for one Kingfisher......![]()
... (at least I'm only planking half of it Point taken !Half of a Kingfisher... (at least I'm only planking half of it
I am also treenailing only half of the hull ...... my luckHalf of a Kingfisher... (at least I'm only planking half of it
very clever ideaMy new electric Treenail maker!!! OK so it's a pencil sharpener, lol I have to say this works really good, I cut a piece of cherry or walnut or whatever you want at 1/4 x1/4 about the size of a pencil and round the corners and that's it, I also got a manual one it also works well, I have a plan for the manual one, I will pull the handle off and connect it to a small electric motor , I've seen it done with a drill,I'll see how long the electric one lasts.
You are absolutely right comparing scraping to sanding specially large areas .It is a disaster sanding indoor and can’t go to the balcony in a bad weather.Cabinet Scrapers
I have been using a basic, rectangular cabinet scraper for years but it only works on flat or convex surface. It will not work on the concave sections of a hull near the stern so I have bought a new set that includes a shaped scraper.
I find scraping the hull planking much more effective than sanding. When flat planks are laid on the curved edge of a bulkhead they naturally stand a bit proud of its surface at their edges. A scraper will concentrate initially on these raised prtions and rapidly eliminate them. Scraping is also less messy than sanding: the scrapings are larger than the dust generated by sanding . They just fall on the bench rather than becoming airborne. This is desirable when working indoors rather than a workshop. If the scrapings are collected and mixed with a bit of PVA glue they make a good caulking material.
interesting. I ordered some.I picked up The Glue Looper for applying tiny amounts of CA glue in just the right area. For gluing these grates together it works fantastic. View attachment 425335
Do they work any better than a needle with half the eye cut offI picked up The Glue Looper for applying tiny amounts of CA glue in just the right area. For gluing these grates together it works fantastic. View attachment 425335
