Small update: I started making the channel & chaine plates in the last three days... It's not all that bad, but it is a very time-consuming job.
Most of the time is spent preparing the photo-edged chain plates, which have holes of 1/64" diameter. There you have to insert a pin that is inserted into the Hull. The holes must be slightly drilled out....
It's a lot of precision work...
PS
I almost finished the spar deck....
I still need to add some Gun rigging...but will be done later on....
PS
