G'day Zoly just been right through your log and enjoying it very much, I look forward to the rest of the build,
Best regards John
Best regards John
**VIEW THREAD HERE** |
Best regards John
Not an easy job but I think it will pay benefits down the line!
What a creation so far! Good idea with the foam. It was a common solution for the folks building ships with card as without it the model would get that sucked in skeletal look between bulkheads. I imagine having a good even surface to plank against will make for perfect seamsHow many sheets of plywood did you end up going through for your keel and bulkheads?
Thanks for sharing this with us. I lived off Lake Ontario for 30 years and had no idea what the English or the Americans were building around here. Never too old to learn!
G'day Zoly
I believe a polyurethane glue is the best type to use.
This photo was taken from a video that use the insulation foam. And Luke on the video mentioned for best results use a polyurethane glue. This one swell up so be careful mate.
Happymodeling
Greg
Looks good to me but quite dusty in think rasping this stuff. Not working in livingroom in hope? Because of the temperatures here now i am alowed to work in livingroom with the airco but the airco blows the dust every where .
I was just looking at your use of foam and it got me to thinking. I wonder if the expanding foam would be good for such an application.
I would be very carefull with this expanding foam, because he will produce pressure against the bulkheads, and partly also against the keel, if you fill only one side, which will be definitely the case. It could be that the basic structure will get deflection or torsion.....I was just looking at your use of foam and it got me to thinking. I wonder if the expanding foam would be good for such an application.
