okayI agree with Doc ! Beautiful !
By the way Kurt, you need to update your forums signature to add this build (and with the results you have, you absolutely need to) !
Jeff
Jeff
Yes. When the boat is on a steady course, weather permitting, you can lash the tackle which is taut to the cleat and ride in comfort. If you need to make slight adjustments, you can throw a half bend around the cleat on the taut side and ease or draw the fall.
I just wanted to build a little boat... not start a revolution!In my opinion, this build has redefined model shipbuilding - certainly the way I think about things! As a showcase for his talent, Kurt won't find any better - love it!
It didn't seem to be anything different that the average scratch build, with a head start on the main parts. I'm surprised this little build made such an impression, and am really glad you guys liked it.Ha! My order of the same 6mm Dry-Dock Models pins arrived two days ago. And they look SWEET! But also, very much a shiny brass and not looking like wood at all. But then again, the Brass Darkening Solution has also arrived. And so, I plan to play with both of those soon. I'll post results, of course.I got some new brass belaying pins from Dry-Dock Models and Parts the other day. Let’s compare them to the others in my parts box.
From left to right:
1) pin from La Couronne kit from Corel, totally unusable if you want the proportions to be correct.
2) brass 6mm pin from Dry-Dock Models
3-5) Falkonet wooden pins, 8mm, 9mm, & 11mm. Note that the 9mm pins are noticeably thinner than the 8mm pins.
The 6mm pins are the smallest and also have correct shape. Plus, they are stronger. Since all belaying pins on models are usually too large for scale, using the smallest pins you can find and work comfortably with is desirable.
Aren’t those little pins cool, though?!Ha! My order of the same 6mm Dry-Dock Models pins arrived two days ago. And they look SWEET! But also, very much a shiny brass and not looking like wood at all. But then again, the Brass Darkening Solution has also arrived. And so, I plan to play with both of those soon. I'll post results, of course.
My guess is that the new oxide will "antique" the brass quite well. Which will be darker than the wood they should have been made out of. But it also may add a neat style aspect. We'll see.
BEAUTIFUL boat, btw.
M.
Sooo cool! I would like to know what type of mini-lathe and what RPM they had to run up to to turn such small pieces as precise as these are. Miniature machine tools fascinate me.Aren’t those little pins cool, though?!
Nude and cleaned with denatured alcohol:Sooo cool! I would like to know what type of mini-lathe and what RPM they had to run up to to turn such small pieces as precise as these are. Miniature machine tools fascinate me.
Kurt, what do you use for a camera? You get some really wonderful quality photos !Day 44
The outhaul for the fore boom was rigged. It’s getting harder to reach in there with fat fingers, guys…
This tiny double chick I gnawed out a scrap stick of cherry wood was a real pain to glue onto the bottom of the fore boom without a magnifying headset.
Hey. I got it!
The outhaul is done.
Hmmm… what do do next…?
I just use an Apple iPhone 12. If you zoom in to 2x or 3x, then move the camera to a desirable distance from the model, you get even focus across the image from left to right and the camera has a better time determining and holding focus. The detail you get is surprising. All the hated fuzzies make themselves apparent.Kurt, what do you use for a camera? You get some really wonderful quality photos !
Tying the stays and keeping them with even intention, such that none of them are slack is always tricky. On this model, simple overhead knots, secure the lower end of the fore stays to the jib. The tension of each line is adjusted before the knots are cinched tight and secured with glue. It’s all about keeping the lines carefully balanced in tension and requires adjustments and patience.Right. So I'm trying to psych up to begin the stays. And I looked back on this thread to where you did the deadeyes. And there was some "hand waving" or explanations that were not as explicit as I guess I might need. I saw how you secured the lower deadeye. But next the upper is shown as rigged up to the mast. How did you get from the lower to the upper plus the mast and keep them all in line (let alone do any of that)?
I built a deadeye jig to hold the two blocks at the same distance while roping them together. But that is definitely not how you work. Can you describe how you work from the lower deadeye to the upper and then mast stay for me?
M.
Hi, Great work, I keep looking at the build and hope I can achieve even a bit of that kind of result. If I may ask a question, how do you get that weathered look on the rails? I am building my first kit of this kind and I guess my question shows it. ThanksDay 46
Guess what, guys! I remembered to bring the magnifying headset this time! Life just got so much easier. The main gaff vang lines were rigged.
First some tiny 2mm blocks need to be stropped to the vang lines and a couple cleats were fashioned from sticks of cherry wood to serve as belaying points.
Two more blocks were stropped to eyebolts. Holes in the stern railing at the corners were drilled by hand. And the end of the fall lines for each tackle were tied to the cleats after estimating how long the lines in the tackle should be. The rigging arrangement was taken from Lennarth Petersson’s book like previous lines. An overhead not is tied around the eyebolt, then the bitter end of the thread are used to tie another overhand not around the block. The thread is secured with CA glue and remainder is trimmed off.
After the cleats were glued to the bulwarks with CA glue, the upper ends of the vang lines were secured to the gaff overhead, tensioning the tackles. The estimates of how long the falls needed to be came out pretty close, with the upper blocks of the tackles being at approximately the same height. These lines are complete.
Next, rope hanks were made, and carefully hung on the belaying pins around the bulwark.
A few more rope coils were also added to the deck.
Progress so far.
Purely by accident. I suck at wood finishing. Basswood takes stain poorly and has no grain contrast. The railings were stained with a few coats of Black Walnut Danish Oil, then spray varnished with Krylon semi gloss clearcote. No rocket science here. Handling of the model also tended to wear the edges of the railings a bit, making them lighter in color. I don't suggest you drag the model behind the pickup truck for 20 miles, but it will get some wear just from handling as you build the rigging, and the finish on my model was not that hard because it took so many coats of Danish oil to get the railing so dark. At least they offer contrast to the hull. If the model had decent hardwoods like cherry or beech wood, it would appear much better, and their would be grain to show, instead of relying on streaks in the stain finish to provide detail. However, since the boat is so small, all the details in the rigging draw you eye away from the wood quality.Hi, Great work, I keep looking at the build and hope I can achieve even a bit of that kind of result. If I may ask a question, how do you get that weathered look on the rails? I am building my first kit of this kind and I guess my question shows it. Thanks
